Center Console pics
Title pretty much says it all. i know i want a center console, ill probably make one. What are you guys using for center consoles. Post em up! include how you got it, or made it and why you did it! Edit: i'm building one for cupholders, head unit, amps, possible subs, small lockbox at bottom for future handgun storage (Only wanna have to do this once
Jack 1968 swb on air Last edited by 68shortwide; 12-16-2014 at 03:47 PM. Reason: Moar Info |
Re: Center Console pics
Here's the one I built that's almost finished. The angled plate just under the dash is removable so I can change the layout of my Switch Panel, GPS or anything else I want to put there. If I get tired of it I can just fab up a new plate and change it. I also have 3 terminal blocks with 6 terminals each mounted under the Shifter Cover. One is switched power, one is direct to the battery and the third is for ground. The whole console is 12" wide.
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
Wow. I had given up on this thread. Lol. That's awesome. I like it.
Jack 1968 swb on air |
![]() Join Date: Feb 2002
1malo68, are those "Bootlegger" brake levers?
I made a stretched cloth/resin style. Made a matching speaker panel for behind my seats the same way. Lots of pics on my build thread on page 3. Configuration is limitless with this method. I wanted to use an aftermarket shifter.. and not use the black cover that comes with them. I have cup holders and a set of tweeters up front.
OrangeSunshine the 2 handles in the console are an ORD twin stick setup for the NP205 Transfer Case. I made them out of some 1-1/4" steel round bar. I wanted pistol grip shifters but nobody made them for 1/2"-13 thread.
Old member
Mine isn't done yet but it's getting close. I had new carpet installed and so I moved the gear shifter and having a 72 center console refrubished.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Andy i like the 2tone with red pinstripe. looks a lot better than when you first posted pics awhile back.
#10 | |
Old member
![]() Quote:
Yea it's looking a whole lot better! ![]()
What primer & paint did you use.......the finish is killer....very nice work........
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
#12 | |
Old member
![]() Quote:
UPstate SC GM trucks Timmy Morris is his name he has a shop behind his house. I'm hoping I get a call from him later this week to pick it up! I will find out what paint and clear he used though. ![]()
![]() Join Date: Oct 2007
Andy ,,they have some to look at in the LMC Catalog ,,for you to think about yours and theirs.. I want to take out my ash tray in my center console and put in a cup holder,, I thought some one on this forum was building them .,, will have to wait until search is back and see ..
When you learn a thing a day you store up smart. |
#14 | |
Old member
![]() Quote:
The guy's name is Frank. Here is the link and the search is working for me always has. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=650980
#15 |
![]() Join Date: May 2012
I have a cheep home made one for now , hope some day to have bucket seats and console....
#16 | |
#17 |
Bump
#18 |
The ones in the console are 1-1/4" solid roundbar that I made and they are on the ORD NP205 Twin Stick shifters
#19 |
Here's the finished product with the Pioneer AVIC 6000 NEX mounted in the console and the kill switch where the old volume knob used to be. The only thing I need to do is put the front cover on the passenger side of the console
#20 |
Not the best pic, but you get the idea. Came from a F-150. Seats from a Dodge Intrepid. I know, it's a grab bag but it is just temporary.
#21 |
Thanks.
