Old 02-10-2015, 02:08 PM   #1
HomerJ
HomerJ's Avatar
A/C - finish out factory setup or install aftermarket?
So, I've read a bunch of posts about upgrading vs repairing/refurbishing the factory item. I already have a compressor, hoses, drier and a few other parts. I would need to get a new evaporator and condenser and possibly a poa valve. On top of all that, I'm not real crazy about the factory brackets (Not to mention the behemoth housing under the hood!)
Would I be better off selling my current parts inventory and going with an aftermarket setup?
Are the aftermarket brackets any better? I have the type that bolts to the water pump and intake manifold (the part I don't like).
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 02-10-2015, 03:05 PM   #2
serge
serge's Avatar
Re: A/C - finish out factory setup or install aftermarket?
I debated same item for 2 years. Have AC cab but needed many pieces, parts and knowledge to get it back to factory air again.
Finally decided to go with aftermarket. Got Vintage Air package and just finished installing last week-end. It works very nicely.
Decent instructions and some great tech support people helped me do it myself which is main reason I went this route.
My 2 cents.
Good luck.
General Contrucktor
serge is offline   Reply With Quote
Old 02-10-2015, 05:37 PM   #3
engineer_gregh
engineer_gregh's Avatar
I got my original up and running on 134a by changing out the POA to a cycling switch. Not completely happy and might end up ripping it out for a modern system. If I keep the old system I really need to change the condenser to the hi flow type or live with the a/c blowing high 40's to low 50's depending on weather.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 02-10-2015, 06:59 PM   #4
knomadd
knomadd's Avatar
I had the same dilemma on my 65 GTO. The PO had ripped most of it out so I went on a few years search and found some parts, but still needed quite a bit. I wound up finding a local hot rod shop that did several swaps and the owner had a Vintage Air setup in his car. Had a 67 Impala in the shop that had a factory system with 134a conversion and he let me compare the two. The Vintage Air system was colder by a few degrees (5-10, can't remember exactly). The smaller compressor and options for mounting (serpentine or v-belt) sold me on aftermarket. I now have a Vintage Air unit in my GTO and my non-A/C '71 C/10. I love it! Cleans up under the hood nicely. Only thing I don't like is the lack of glove box.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-10-2015, 11:17 PM   #5
glens/72
glens/72's Avatar
Go with gen five. No cables to dick around with.
glens/72 is offline   Reply With Quote
Old 02-10-2015, 11:28 PM   #6
hdff
hdff's Avatar
I Am in the process of gathering what I need to get the factory unit running again. One of my concerns if I go aftermarket is what the firewall will look like when the evaporator housing is gone . My truck is not the factory color and the fire wall behind the housing is
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-10-2015, 11:39 PM   #7
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Go vintage air!! Great units.. I've sold and installed more than I can count. Never have had a return yet.
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-11-2015, 12:28 AM   #8
colgad
colgad's Avatar
Do not repair the OEM unit.
Vintage Air, just works and easy to install.
You even get a new Air control plastic guide that has the corrected face.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 02-11-2015, 12:55 AM   #9
kamikazekyle05
kamikazekyle05's Avatar
For any of you guys that have had both, how is the air flow out of the vents between the two?
kamikazekyle05 is offline   Reply With Quote
Old 02-11-2015, 08:09 AM   #10
MARKDTN
If the engine brackets bother you, get a new Sanden compressor and brackets. That solves the A6 compressor issue and gets you pretty brackets. I would stay original if you have most of it. Since you don't have a condenser, you could upgrade that pretty easily.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-11-2015, 09:43 AM   #11
serge
serge's Avatar
Not sure what to do about color concern but for me the new space was perfect for radiator coolant recovery tank.
General Contrucktor
Old 02-11-2015, 09:58 AM   #12
cericd
cericd's Avatar
Is there a way to use a Vintage Air setup and retain full use of the glove box? Also, does the Vintage Air setup affect the use of the passenger fresh air vent?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 02-11-2015, 02:22 PM   #13
serge
serge's Avatar
Having just installed one in 70 c-20, I do not see any way to maintain full glove box. Unit tight to firewall and due to depth of unit the glove box space has to shrink. Maybe somebody could build out a cavity in firewall but that's over my head.
Regarding fresh air vents its your choice. Per Vintage tech says its important to close vents during operation. Since vent almost entirely covered I removed and covered with provided cap.
General Contrucktor
Old 02-11-2015, 06:48 PM   #14
knomadd
knomadd's Avatar
You still have a glove box, just very minimal. No way to keep the original glove box with any aftermarket unit I've seen. They all install under the dash so they don't protrude into the engine bay. Here's what it looks like without the liner:
Name:  2014-07-27 10.25.26.jpg
With the glove box liner:
Name:  2014-08-30 19.26.58.jpg
You're supposed to seal off the fresh air vent, but I didn't. I conveniently "forgot" and the A/C functions fine. I can still open it... not sure if it's limited or full travel. It's been a while since I looked.
-Duane
Old 02-11-2015, 07:27 PM   #15
72MARIO
72MARIO's Avatar
I guess I am the only one that does not like my aftermarket ac,...
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-11-2015, 10:32 PM   #16
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: A/C - finish out factory setup or install aftermarket?
I say go with stock looking parts but change them to 134a with orffice tube system. This is what I did and mine works great. 38-45 degree's in the mid of summer.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-11-2015, 11:44 PM   #17
HomerJ
HomerJ's Avatar
First, thanks for all the info!
For those that don't like your aftermarket units, what did you go with and what about it do you not like?
I have the same reservations about the glove box and fresh air as others have stated.
Does anyone make an aftermarket bracket that bolts to the head? I have am aftermarket alternator bracket on my Chevelle, but can't remember the name of the company that made it (first sign of old age!)
Old 02-11-2015, 11:53 PM   #18
ole dollor
ole dollor's Avatar
if you have most all the parts, not sure anything would beat the factory set up . if you did not have a factory air cab ,then you could buy the after market in dash air.... just saying .
ole dollor is offline   Reply With Quote
Old 02-12-2015, 12:00 AM   #19
72MARIO
72MARIO's Avatar
I don't like not having the ability to blend the tempature or access outside are. I have a old air setup. All aftermarket is the same junk..only inside is is recirculated.
2005 TAHOE DD
Old 02-12-2015, 12:59 AM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
x2
Old 02-12-2015, 03:26 AM   #21
RedRoad
RedRoad's Avatar
Looks great! Have a parts list for the conversion?
RedRoad is offline   Reply With Quote
Old 02-12-2015, 04:08 AM   #22
Andy4639
Old member
Andy4639's Avatar
Cool Re: A/C - finish out factory setup or install aftermarket?
No sorry I don't, I did this mod close to 20 years ago.
That's what the diagram at the bottom was for. You buy the same parts but just get them for 134a. Left side is 134a stuff.
Here is who I bought my stuff from.
I had like $900.00 in everything.
http://www.classicautoair.com/
