Old 02-12-2015, 12:00 PM   #1
The Swed
The Swed's Avatar
Bad Radio or bad speaker?
I turn my radio on all the way and I can hear it just barely. My guess is that the speaker is bad? Does the radio in these truck have issues over time?
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 02-12-2015, 12:08 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Bad Radio or bad speaker?
can you get you hands on a known working speaker? splice that one in and see if you get music. but not for long if its a 4 ohm. itd be better if you can find an 8 ohm. or wire two 4 ohm in series.
meaning positive of one speaker to negative of matching speaker. this will turn two 4 ohm speakers into one 8 ohm speaker. id start there
1967custom
michael bustamante is offline   Reply With Quote
Old 02-12-2015, 12:16 PM   #3
The Swed
The Swed's Avatar
Okay, thanks Michael.
Old 02-12-2015, 12:21 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
They can, the volume control can get dirty or corroded, but I find most issues are with the speaker. Unless you have someone in your area that re-cones speakers you have two options for the stock type stuff.
I bought one from Electro-tech. Sounds a lot better than the original I had in the '70.
http://www.turnswitch.com/speakers.htm
Scroll about half way down the page.
I also had two original speakers re-coned by Jackson Speaker Service in Jackson Michigan. I don't think they have a web site but here is there contact info:
https://plus.google.com/105846875566...ut?gl=us&hl=en
At the time I had mine done they were $50 each.
LockDoc
Leon
Old 02-12-2015, 12:26 PM   #5
The Swed
The Swed's Avatar
Great info! Thanks LockDoc. Is the factory/stock speaker a 4 ohm or an 8 ohm?
Old 02-12-2015, 12:35 PM   #6
LockDoc
LockDoc's Avatar
Cancel that last post.... The original is 10 ohm. Sorry. And don't turn the radio on without the speaker connected it can blow out one (or more) of the transistors.
LockDoc
Leon
Old 02-12-2015, 12:49 PM   #7
The Swed
The Swed's Avatar
Okay, thanks again Doc.
Will an 8 ohm still work?
Old 02-12-2015, 01:04 PM   #8
hamjet
hamjet's Avatar
The one LockDoc mentions is the one I got two years ago, 10 ohm Delco style special rectangle 4 x 10. He's correct , don't turn it on till you're sure if the speaker is bad, it'll burn out the transistor output if left on too long. wasn't too bad changing, pulled out the ash tray removed hardware off the front of the radio, laid on my back to look under dash to remove radio first, then speaker...PS, check the antenna connection first.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 02-12-2015, 01:11 PM   #9
LockDoc
LockDoc's Avatar
I don't know, but if you value your radio I wouldn't try it....
LockDoc
Leon
Old 02-12-2015, 02:02 PM   #10
The Swed
The Swed's Avatar
Roger, that...
Old 02-12-2015, 03:15 PM   #11
cdowns
cdowns's Avatar
I'd first clean and reattach the ground to the radio
Old 02-12-2015, 03:30 PM   #12
michael bustamante
i thought the original am radios were 8 ohm.
learn something new everyday. even when i think i know it all!
1967custom
Old 02-12-2015, 03:37 PM   #13
hooverfish
hooverfish's Avatar
LockDoc
I bought one from Electro-tech also and agree with LockDoc. New is nice in this case. They sell a good product.
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 02-12-2015, 09:05 PM   #14
franken
Stamped in the metal of the radio is "do not operate without an 8-10 Ohm speaker" so I'd guess 8 is ok.
Old 02-13-2015, 10:39 AM   #15
BLT gmc
The best thing to do is to check the resistance across the speaker with a multi-meter. If it is not in the 8 to 10 ohms, the Delco will get hot quickly and open either output transformer just as quickly. Bruce
BLT gmc is offline   Reply With Quote
Old 02-13-2015, 12:52 PM   #16
67chevemall
67chevemall's Avatar
Purr of the motor is all you need!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-13-2015, 01:02 PM   #17
michael bustamante
oooooh yeahhhhh. some ramhorns and flowmaster super 40`s rumblin under the truck is music to my ears
ok were off topic now.......................
1967custom
Old 02-13-2015, 01:55 PM   #18
The Swed
The Swed's Avatar
My truck came with full length headers, flowmaster and now a big smile on my face going down the road! It's been over thirty years since I've had a V8 and I'm not going another minute without one.
Old 05-02-2016, 02:52 PM   #19
The Swed
The Swed's Avatar
Update! I replaced my speaker with one from LMC. The old speaker was a 10 ohm and the new one is 7.3 ohms when hooked up in series. It works great. BTW the speaker came with the bracket backwards... Just had to flip it and it was good to go!
