#351 |
Re: 64 C10 Stepside "Jaybird"
Looking good!!! That satin white is sweet.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
#352 | ||
Thanks Dwcardfan.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#353 |
Had another really nice 70* day today. Was warm enough I was able spread some filler on the back of the cab and finish up all the bodywork. I spent quite a bit of time on the outside back corners of the cab as this is all visible on a stepside. Both sides had their share of dings and I hammered and dollied as much as I could. Used the new Rage Gold filler I got for Xmas. This stuff is awesome lays down real smooth like peanut butter and has virtually no pinholes and sands real easy. The weather started to chill in the afternoon so I was not able to shoot primer. Couple of coats of filler primer and some blocking and the cab is ready for some Midnight Blue!
#354 |
Funny how these build threads are like a drug.
I am sitting having a quick coffee in a hospital before getting out to go hunting again and checked in. That filler sounds like a rather good investment. Progress is Progress.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#355 |
I agree Rian. I read people's build threads before I go to work in the morning and usually read them when I get home.
#356 |
Stripped my passenger door yesterday. Found some stuff I really didn't want to but that's how these old trucks are. Surprises around every corner. The front corner is rotten. That is a relatively easy fix. It appears the door check broke at one time and the door was allowed to swing to far and crease the door. The body man that fixed pulled some of the dent and then filled over with a 1/4" bondo. I swear I ground at least a quart of bondo off this door.
So I will have to cutout the two creases and weld in some new metal. There is also a crease running down the bottom middle of the top curve part. Not sure I can really do anything with this and it is not that deep so will probably just fill over it. Does any of this look familiar Rian? ![]() ![]() ![]() ![]() Looks like an ANGRY BADGER was riding shot gun and beat the hell out of the bottom of the door. I am really curious how this even happened as the original rocker had no damage in this area? Was going to bang this out from the inside since there is a speaker hole but there is another panel behind it so no access. Probably just cut it out at the edge and then hammer the edge square and weld in a new piece. ![]() Also the door check area is beat up as well. Must have been a violent wind whipped the door or something who knows! ![]()
#357 |
The joys of P.O.s
![]() Small potatoes for you Brotha!!! ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#359 |
What have you decided about the doors, are you going to re-skin them up to the window frame?
#360 |
My current plan is to make some wooden pucks that match the profile of the two outer areas I need patches for. Make some patches and then trace them out over the damaged area cut out and weld in the patches. I don't really want to replace the whole door skin. I found a tool online that I might be able to use to push the crease out from the inside.
#361 |
What tool?
#362 |
Hey bj383ss, do you have Facebook?
#363 |
Its basically a 1/2" bar with a right angle at the end with a rubber tip. They are pretty expensive. I may try to make one myself. I watched several videos on youtube of PDR and guys using them on newer cars. But they have thinner metal so not sure it will work on the older metal. Will find out.
http://denttoolsdirectusa.com/product-category/rods/ Yes I do and you are already friends with me. HA!
#364 |
Haghaha.... 15 pages later and 2 cups of coffee! LOL Great build man! Nice work! Subscribed
64 LWB to SWB Step build. Daily driven! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
#365 |
looks easy compared to what you done but if your budget will allow it there are some straight doors over in the parts forum,
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
#366 |
Man my thread was back on page 4. I have been slacking. Had some truck time today and also spent about 4 hours talking truck with 66customcab. Studied a lot of things on his truck to see how they came from the factory. Got a real good idea of where to tape off on the front grill for the white, black and blue. I also discovered I have a Custom cab bench seat by the extra springs mine has. Same as his. Very cool getting to meet him and his truck today.
After he left cleaned the shop real good and started masking off the white and getting ready to spray the Midnight Blue. Very excited. It was 60* today and this coming week we have 3-4 days we are suppose to hit 70* so I want to have the bottom part of the cab ready to go. Unmasked everything and pleasantly surprised to have no overspray of white onto the California Suede Metallic. ![]() The masking tape I bought is pretty awesome. Even for an amateur like me I got really good crisp lines. And the tape is see through which I didn't understand and first but now I do. It lets you see the previous tape line easy to see when you are masking to spray the second color. Awesome. ![]() I also got the back cab wall sanded so I can reshoot it. ![]() ![]() Also had a bonfire and burned all the tree trimming from a couple weeks ago. ![]()
#367 |
Progress and Fire...
#368 |
"FIRE FIRE FIRE FIRE" in my best Beavis voice
#369 | |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#370 |
Thanks for the offer John. I really don't want to replace the whole skin. Will see how I do on it.
#371 |
Couple of rounds of high build and blocking on the back and she will be ready for some paint.
#372 |
![]() Join Date: Oct 2009
good work man. we're gonna get a few days of nice weather also and painting is in my immediate future. good luck to you with yours.
and i like the cab stand you made. |
#373 |
Looking good Bret
you will have it back on the chassis in no time
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
#374 |
A quick question on the primer. Does everyone sand the primer everywhere before applying the base coat or SS?
#375 |
Ron
The sealer primer shot right before color has to be wet. I let it flash for about 15 min before the color
