Old 02-13-2015, 03:33 PM   #26
El Dorado Jim
Re: Quadrajet or Quadra-throw out the dang window!!
Originally Posted by D.PASSMORE View Post
If you need to get the truck moving and are going to use it as a daily driver. This is your best option ^^^^.
Sometimes when I get to a point with a engine problem (timing or fuel) and can't determine the cause, I will break out the ole Edelbrock and bolt it on to see what changes occur. They are easier to tune. But, remember a Edelbrock is a square bore and a Q-jet is a spread bore. You will need a adapter plate or a square bore intake manifold.
I run edelbrock air gap manifolds and 1" spacers
El Dorado Jim is offline   Reply With Quote
Old 02-13-2015, 06:50 PM   #27
Eddie H.
Eddie H.'s Avatar
If you can find a good "virgin" Quadrajet that has never been messed with/messed up by somebody that don't know what they're doing, then rebuild it correctly, they are one of the best carburetors that has ever been built. The problem is that they haven't been produced in many years and most of the available cores are either completely worn out or butchered up beyond repair. For a daily driver, I would just get a new Edlebrock 1406 for about $300, bolt it on and go. All the ones I have ever used are extremely reliable and run fine straight out of the box.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-13-2015, 07:05 PM   #28
GRX
GRX's Avatar
Not to start any arguments. I understand many like them. Those Edelbrock AFB clones make me cringe.
GRX is offline   Reply With Quote
Old 02-13-2015, 08:13 PM   #29
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That makes 2 of us. Again... I know cats swear by them. But you couldn't pay me to use one.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
