02-15-2015, 03:14 PM | #1 |
Gauge Cluster
I have a 70c10 with a 3 hole cluster, I guess its called. It also has one of those cheap sunpro 3 gauge things hanging under the dash. I would like to switch to a cluster with all the stuff in the same spot. I have a spare one that has the 4 holes on the bottom, but I am not sure if it would just plug in to my truck or not? I also would need to change the battery gauge and stuff I think. Has anyone ever modded their cluster to update it like this. Maybe I can put the sunpro gauges in the 4 hole one or just cut the one I have? I also want to add a tach somewhere in the cluster. I don't want to buy one of those 400 plus ones. Any ideas or pictures would help a lot. Thanks.
02-15-2015, 03:29 PM | #2 |
Re: Gauge Cluster
02-15-2015, 03:55 PM | #3 |
Re: Gauge Cluster
One of the site's sponsor's-gmcpauls- website has instructions on how to convert from your dash to the 'newer' one
here is the link http://www.gmcpaulstruckparts.com/Tech%2520Tips1.htm |
02-15-2015, 08:49 PM | #4 |
Re: Gauge Cluster
That's some great information in the link provided above. Chances are some of those gauges may not work, so you may want to check that stuff. You'll also need to make sure you have the correct water temp sensor as not just any will work. Your 3 hole panel looks in good condition, you can probably score some money if you flip it. Drill holes in it and it's worthless at that point.
