Old 02-14-2015, 10:56 PM   #1
Gregski
Gregski's Avatar
Does the Output Yoke slide out? Muncie 4spd
In order to remove the drive shaft from a Muncie 4 speed transmission can you just slide the drive shaft out towards the rear of the '74 truck?
I had to unbolt the pinion yoke/flange straps on mine
my terminology may be all way off, so here is a pic of what I am talking about
Gregski is online now   Reply With Quote
Old 02-14-2015, 11:28 PM   #2
buddy_1
buddy_1's Avatar
Re: Does the Output Yoke slide out? Muncie 4spd
That style yoke is bolted on. Look in the middle of the ears and remove the attaching bolt to remove the yoke. Buddy
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 02-14-2015, 11:47 PM   #3
greg64
greg64's Avatar
Ya, Greg, there's a big bastard nut on the end of the transmission output shaft that holds the yoke on. Unlike turbo 350/400 (and many others) which have the driveshaft yoke as a slip (splined) joint, the sm465 puts the slip joint in the shaft itself.
The way you took it apart is completely correct (taking the straps off the ujoint).
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-15-2015, 02:10 AM   #4
Gregski
Gregski's Avatar
thanks I thought the shaft ought to travel in and out a bit as the rear suspension gives or especially when you lower the truck, is it because we have a two piece drive shaft that it doesn't have to go in and out of the tranny
by the way I only wanted to take it out / remove it if indeed it was supposed to slide out, in that case I wanted to ensure it glides in and out as it is supposed to, no need to take it out now that I know it is a fixed design
thank you very much again
Old 02-15-2015, 09:22 AM   #5
There should be a slip yoke in the driveshaft
Old 02-15-2015, 10:27 PM   #6
hatzie
Moderator
hatzie's Avatar
An original SM465 should have a 2 piece driveshaft. A slip joint is between the axle and the carrier bearing and a short shaft between the carrier bearing and the tranny.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
