Old 02-10-2015, 08:56 PM   #1
chico68
spark plug wires
I have a 1968 chevy k 20 with a 350 and HEI ignition. I need to replace the plug wires, but don't want to mess around fitting and assembling them. I have the stock ram horn manifolds on. Does anyone know of an aftermarket set made for this HEI conversion or something that works great. I haven't had much luck with the sets I have used in the past. Thanks
chico68 is offline   Reply With Quote
Old 02-10-2015, 09:07 PM   #2
454chev
Re: spark plug wires
plug wires from a 1975 and newer corvette with HEI will fit because they went down along side of the block.
454chev is offline   Reply With Quote
Old 02-10-2015, 09:07 PM   #3
Mike C
Mike C's Avatar
'75 Corvette wires. HEI with rams horns route the same way as the OEM truck wires did below the manifolds.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-10-2015, 09:13 PM   #4
Churchill
Churchill's Avatar
MSD Super Conductors!
Churchill is offline   Reply With Quote
Old 02-10-2015, 09:20 PM   #5
Mike C
Mike C's Avatar
454chev, our posts were almost exactly the same wording at exactly the same time!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-10-2015, 09:33 PM   #6
Lanman1972
Lanman1972's Avatar
I bought a set of Taylor wires from Summit, about $60 and routed fine. Lots of options for color and boot angles.
Lanman1972 is offline   Reply With Quote
Old 02-11-2015, 04:23 PM   #7
fp1967
fp1967's Avatar
I use wires for a 1975 454, they have straight boots and I go over the top of the ramhorns. Standard #6810. If you're not familiar with Standard, it is a brand that my local parts store has been selling for years. I believe the company name is Standard Motor Products. Here are a couple of pics of my C10 engine, I also use these wires on the K10 in my avatar.
fp1967 is offline   Reply With Quote
Old 02-11-2015, 07:26 PM   #8
1stchevy
1stchevy's Avatar
Another vote for Taylor wires, give them a call they'll tell you what you need. They even told me where to order to get a better price!
1stchevy is offline   Reply With Quote
Old 02-13-2015, 02:47 PM   #9
72CampSpecial
Where do I find the heat shields that are install on your engine in the pics? I keep burning through my #6 plug wire. I added Kevlar sleeves and that helped, but the #6 still burned through eventually..
Will they work on a 350?
thx..
72CampSpecial is offline   Reply With Quote
Old 02-13-2015, 03:31 PM   #10
Mike C
Mike C's Avatar
Restoration places like Classic Industries or LMC should have them. But run the plug wires underneath like they were originally and you are less likely to have any troubles.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-13-2015, 06:22 PM   #11
JointTech
JointTech's Avatar
need more pics guys!! I was just saying to myself I dont see how you get your wires so cleanly routed. This was the best I could do ;(
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 02-13-2015, 06:42 PM   #12
jocko
jocko's Avatar
with headers that close to the block, recommend going over the valve cover and not under the header. Not as clean as the factory look, but you're likely to burn #1/#3 in the above pic. There are several companies that sell a bracket that runs along the outer edge/lip of the valve cover - that'd work pretty well in this situation. I'm not a fan of the look of aftermarket looms/brackets, but sometimes they serve a purpose. Rams horns, I'd go under like the factory - headers, I'd go over the valve cover and keep them away from the headers as much as possible, to include angle boots.
Old 02-16-2015, 04:28 PM   #13
chico68
Thanks guys great information. I went with fp1967 and got the big block wires they work fine, its the best set up I have used so far.
