02-16-2015, 11:31 AM | #1 |
Help me identify these parts
Ok, these are the parts that were on my firewall when I removed the steering column on my 66.
Not sure if these are correct for my year but if you could tell me what they came off and the correct name so I can get replacement parts OR the correct part for my year truck. I am using an ididit column for a 66 with manual shift on the floor. thanks!
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
02-16-2015, 12:29 PM | #2 | |
Re: Help me identify these parts
02-17-2015, 12:40 AM | #3 |
60-66 Nut
The rubber piece on far right and bottom, is not original. The foam seal piece is sandwiched between the metal plate and the firewall to seal the OD of the column to the firewall. The plate attaches to the ribs inside the firewall with 4 sheetmetal screws.
