Old 12-01-2014, 05:33 PM   #1
LudwigTheMad
LudwigTheMad's Avatar
Talking Just to keep active, here is what I am in the middle of doing to my burb
I have removed all the wiring, adding in a new wire harness with buss type fuses, pulled the two small gas tanks out, and adding in an original 45 gallon single tank.
New rear springs, new performance shocks and a set of load helpers and a class 3 hitch......
Trailer brake control to be installed as part of wire upgrade.
A few other minor upgrades that were needed, like changing the boneheaded previous owners boneheaded mistake of NOT removing the resistor wire when he converted to HEI....ahahahahahahahahahahahahhahahahahhhhhhhahahahahahahahhahahahahahahbwaaaaahhhhhaaaahahahahahah ahah.
9 out of 10 personalities agree that under-powering your coil is bad for your engine.........
the tenth one is in the corner trying to zap fleas off of his skin with a hand held stun-gun...........
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 12-02-2014, 01:18 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Just to keep active, here is what I am in the middle of doing to my burb
Glad to see you are working on it but where are the pictures??????..
LockDoc
Leon
Old 01-16-2015, 04:30 PM   #3
LudwigTheMad
Here are a couple of pics. The cab shot shows 1/2 of the new harness done. The hood shot is post demo, but no new wire has been done. some old harness wire left to use as a pull wire.
Progress is slow due to my back, but we have managed to get the under the hood almost done. Trying to finish the under the hood portion done this weekend.
Cab is mostly done, with the exception of the new digital dash, will take new pics this weekend.
In the hood shot, you can see the new grill already installed.
Old 01-26-2015, 01:44 PM   #4
LudwigTheMad
Updated underhood pic. Front end harness done, rear end harness done. Suspension upgrade done. New 45 gallon tank and third seat still to go in. Tow hitch and trailer brake ready to go in. Digital dash ready to go in.
Old 02-17-2015, 05:37 PM   #5
twistedchevy
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
