Old 02-15-2015, 10:38 PM   #1
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Power setting kit feedback?
Has anybody used the kit that lets you install a 1969-87 Chevy 2WD power steering box in a 1955-59 Chevy pickup? Any feed back on fitment or other things it affects?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 02-16-2015, 01:52 AM   #2
Clarance J
Clarance J's Avatar
Re: Power setting kit feedback?
Hello 1-ton of fun. I got a kit for my 55.2. One thing I didn't like in the kit was the 1/2'' spacers. They just seemed too small and offered no frame support. I ended up using 1/2'' bar stock as spacers with a plate inside of frame for extra support. As for affecting other things its a chain reaction. There are a bunch of things that have to be looked at like the tie rod, column, U-joints, pump, hoses, what kind of brackets for the pump and pulleys. I used a 79 box and I do like the power steering. I might be able to answer some questions and if not there are more builders who have used these kits. Some like the box up front and some don't. I'm OK with it. Good luck.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 02-16-2015, 09:27 AM   #3
Russell Ashley
Russell Ashley's Avatar
I don't recommend that kit. I had it but removed it for a better suspension. If you really want to keep the straight axle I think the kit that mounts a p/s box in the original position is a better alternative due to the fact that the drag link remains the original length.
Russell Ashley is offline   Reply With Quote
Old 02-16-2015, 01:28 PM   #4
1-ton of fun
polishing a turd
Good to know. The motor going in already has a pump on it
Old 02-16-2015, 03:08 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Have you thought about something like this setup. we just did this to a 47 1 ton a short time ago and they really like the way it handles. Turns lock to lock on the stock axle. Same as on 58 to 67 chevy and 67 to 81 corvette
Old 02-16-2015, 07:04 PM   #6
1-ton of fun
polishing a turd
Something like this?
http://www.brotherstrucks.com/prodin...number=PSCS059
Old 02-16-2015, 07:13 PM   #7
octanejunkie
octanejunkie's Avatar
Originally Posted by 1-ton of fun View Post
I have the CPP version of that kit on my '59. The kit I bought came with an adjustable drag link and a newly manufactured pitman arm.
I used a double u-joint to accommodate the offset between the box's shaft and steering column (chevy van tilt column in stock location)
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 02-16-2015, 09:04 PM   #8
Dan in Pasadena
Dan in Pasadena's Avatar
Dave, Whose kit is that? Have you driven it, and if you have what did YOU think of its driving manners?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is online now   Reply With Quote
Old 02-16-2015, 09:37 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
We made the kit here using 67 C10 assist cylinder and mounting parts and a corvette control valve. The drag link portion I made on my lathe and I used a Jeep rod end for the front joint. Its steers very well, the people I built the truck for love it, the wife drives it several days a week, Its not one finger steering but a very good assist, she doesn't have any problems and its a 1 ton. I think it drives very well and it runs 65 with no wander or twitching, stays in the lane and you don't have over steer to keep it in the lane. I'd use it again as an alternative for those wanting the straight axle but adding P/S but don't want the Saginaw box and its issues or don't trust a rack on the beam. Another nice thing is it looks almost like it belongs there, more period correct which was what we were trying to do.
Old 02-17-2015, 03:27 PM   #10
Apachemike
Apachemike's Avatar
Watching....my kit is on the way
Apachemike is offline   Reply With Quote
Old 02-17-2015, 04:43 PM   #11
1-ton of fun
polishing a turd
Can you make another, and how much?
Old 02-17-2015, 06:12 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
I sent you a pm
