Old 01-09-2015, 12:46 PM   #26
67 cst swb
67 cst swb's Avatar
Re: WTB... 327 Block
Originally Posted by jmader View Post
Well, Yes...
But that shows me some interesting info.
It shows a V 1104 YH with a Block Cast Date K 3 6
which tells me the block was cast on Nov 3rd and assembled Nov 4th
So, maybe I should be looking for a much closer to Dec 20th 1966 cast date
Hmmmmmmm... very interesting that the cast date and assembly date are that close.
So... I am revising my search...
I am now looking for a Mid-Dec cast date block.
Ideal find would be a 3892657 block cast date of L-10-6 to L-19-6
Jmader, thank you so much for finding me that info.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-09-2015, 01:06 PM   #27
jmader
jmader's Avatar
I think these things were pretty random. The 327 I found for my truck has a casting date of E-4-6 but the engine pad is stamped F0505YM (the casting #3858174 was not used in 1966 vehicles) so this block sat around for over a year before it was used in a truck. You just never know
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 01-09-2015, 01:30 PM   #28
67 cst swb
67 cst swb's Avatar
I agree, I think they were pretty random.
But, If I can stumble across a 3892657 block with a cast date of between L-10-6 to L-19-6
I think it would be a no brainer in not having to explain the huge date difference.
My Trucks:
Old 01-12-2015, 12:00 AM   #29
67 cst swb
67 cst swb's Avatar
I am still looking for a 3892657 block cast date of L-10-6 to L-19-6
My Trucks:
Old 01-12-2015, 09:18 PM   #30
SS Tim
SS Tim's Avatar
Since the block (3858174) was used from 64-67 and a YH coded block is correct for a 66 C20-30 w/M49 (TH400), I'd say its originally out of a '66 truck.
SS Tim is offline   Reply With Quote
Old 01-12-2015, 09:33 PM   #31
SS Tim
SS Tim's Avatar
Originally Posted by 67 cst swb View Post
Well, Yes...
Since I know you are not looking to stamp a block don't fixate on a specific casting number or casting date range. Use those to help find a correct or very closely dated block based on the engine assembly number. But it does confirm what I have been saying. Your correct block with the assembly code V1220YH
could very well have a casting date as late as L 19 6 and it is probably a 3892657 casting number.
If we locate an original engine on or very closely before that assembly date it will then be a decision if its "close enough" or a reference for the casting numbers and dates of all the major components as would have been used on your vehicle to futher narrow the search.
Old 01-12-2015, 10:42 PM   #32
jmader
jmader's Avatar
What's your source that says the YH was used in '66 trucks? I could never find anywhere that said that. You're probably right though that would explain the big date gap.
1967 Chevy SWB K10
Build thread-
Old 01-12-2015, 11:09 PM   #33
SS Tim
SS Tim's Avatar
This is from the 46-72 Chevrolet series 10 20 30 truck parts manual dated 5/79.
Old 01-12-2015, 11:21 PM   #34
jmader
jmader's Avatar
Oh sorry my block is a YM suffix not YH. I don't see the YM in that list. Do you have any more info on the YM?
1967 Chevy SWB K10
Build thread-
Old 01-13-2015, 12:53 PM   #35
67 cst swb
67 cst swb's Avatar
I am mostly interested in block with casting number of 3892657
and a casting date of L 10 6 to L 19 6 (rear pass side of block)
My Trucks:
Old 01-13-2015, 01:09 PM   #36
67 cst swb
67 cst swb's Avatar
So, are you saying I should not be searching for a L 10 6 to L 19 6 cast block and that I should be looking for a V1220YH stamped assembly code block?
I was kind of thinking of getting a block that "could have been correct" simply due to casting date. Of coarse... ideally a V1220YH would be awesome. I guess I was just not dreaming that big.
And, based on the sheet above... How did my 1967 1/2ton have a YH code?
My Trucks:
Old 02-18-2015, 10:54 AM   #37
67 cst swb
67 cst swb's Avatar
ttt
I am still looking for a 327 stamped V1220YH (front pass side in front of cyl head) or
My Trucks:
