Old 07-03-2014, 10:30 AM   #26
Budman56
Budman56's Avatar
Unhappy Re: Need help with my pulley set up for my 65 v8
Originally Posted by 60-66 View Post
That's the reason I gave you the GM part number that IS correct for 1966. Its a Positive way of identifying parts. Your CAST pulleys are 100% GM and have the part number cast in them. Your power steering PUMP AND BRACKET are from 1969-1972 truck. This is what I said Im not certain they will work because it MAY be a different offset than the correct 1966 pump and bracket. Theres at least 3 different single groove PS pulleys, all different offsets . I can see right off that the one he sent you is the wrong offset. Is there a GM part number in this new pulley ?
6066 I must be slow because I don't see the part number you gave me, Can you give it to me again?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 07-03-2014, 10:41 AM   #27
padresag
may be on the other thread
ron
padresag is offline   Reply With Quote
Old 07-03-2014, 10:42 AM   #28
60-66
60-66's Avatar
It was in your other thread on this issue, but I posted it above also. 3791943
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-03-2014, 11:27 AM   #29
Budman56
Budman56's Avatar
Talking Re: Need help with my pulley set up for my 65 v8
6066 thank you I have copied and posted the photos of the pulley you have suggested here in this post, I have bid on the pulley so we will see if I am able to get it. Also as a side note I called Allen grove components again this morning to canceled the order I placed last night and talked to him some more about my problem with the pulley alignment and gave him the part number you gave me he says he has that part in stock but doesn't believe that is will fix my problem. Well see I will post when I receive / or win the pulley and install it on my truck. I am keeping my finger crossed and hope this fixes my pulley problem.......Thank you all for your input. I also noticed that woogo posted this in the FAQ for those who will have this problem in the future.
As a side note for all reading this is the correct GM PART NUMBER 3791943 FOR FACTORY AIR WITH CAST IRON PULLEY. PER 60-66
MY 65 C20 BUILD
Old 07-05-2014, 07:40 PM   #30
Budman56
Budman56's Avatar
Here is a link to Wiki link to the gm pulley it also as a link to ebay and will find the pulley if its on ebay at the time your looking for it.
http://www.gmpartswiki.com/gmpart?gmpartno=3791943
MY 65 C20 BUILD
Old 07-13-2014, 02:26 PM   #31
Budman56
Budman56's Avatar
Thumbs up Re: Need help with my pulley set up for my 65 v8
So here is the end to the story the pulley that 60-66 found for me on Feebay was the correct pulley and now is installed on my truck. thank you again 60-66!
MY 65 C20 BUILD
Old 07-13-2014, 08:19 PM   #32
cortcomp
cortcomp's Avatar
I just went through this with a 327/air/ac/ps truck, had to add a 1/4 spacer to bring crank pulleys out to line up...water pump pulley couldnt go on more or itd rub the water pump housing. PS was slightly off but just came back from around 500 mile trip and no problems. Never did see if it was balancer or new.timing set that caused the offset. Excuse typos, typjng this on phone.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-13-2014, 08:20 PM   #33
cortcomp
cortcomp's Avatar
Didnt see that you fixed it, damnit slow loading phone! Good to see you got it!
Old 02-19-2015, 09:01 AM   #34
Ronw435
Ronw435's Avatar
Hey thanks for all the pictures and responses. I now know what I have to do. This forum is awesome!!!!
Thanks again.
Ronw435
Ronw435 is offline   Reply With Quote
