Old 02-20-2015, 09:31 PM   #1
smokie
Alternator questions
I recently purchase a 71 C10 that was wired as a single wire however that alternator died and the only replacement listed is for a stock remanned unit externally regulated unit. The truck was "unfinished" in the way of no heat, AC, radio, etc. However I'd like to readd these things back into the truck. I have an optima blue top battery I plan on installing also.
Would you all recommend keeping a 1 wire alternator or switching to a 3 wire?
If so a 3 wire, how do I wire it in? Which amperage?
If so a 1 wire, which amperage?
Please include recommendation on the parts (Company, part #) if you can.
Specs on the battery:
Battery Type: Sprial AGM
BCI Group Size: D34M
Cold Cranking Amps: 750 amps
Cranking Amps: 870 amps
Thanks in advance!
smokie is offline   Reply With Quote
Old 02-20-2015, 09:33 PM   #2
enaberif
Re: Alternator questions
1 wire for better flexibility and upgrade options. You could easily upgrade to a CS130 for more amperage if you wanted.
enaberif is offline   Reply With Quote
Old 02-20-2015, 09:43 PM   #3
smokie
Updated first post with more information
Do I need more amperage?
Old 02-21-2015, 12:07 AM   #4
Jason Banks
Jason Banks's Avatar
Checkout the MadElectrical.com website. Lots of good info there.
Start on the TECH page but the following articles stand out:
http://www.madelectrical.com/electri...hreewire.shtml
and
http://www.madelectrical.com/electri...elcoremy.shtml
To answer your question "Do I need more amperage?" - We have no idea how many amps you were getting from the 1 wire alternator. If you set it back up to work with an external regulator and 42 amp alternator your probably going to notice a difference. I know going from a 42am to a 63 amp 10si makes a difference. That would be my recommendation.
I would get this: http://www.amazon.com/dp/B001KR2GVI/ref=wl_it_dp_o... http://www.amazon.com/dp/B001KR2GVI/ref=wl_it_dp_o... and straighten out the wiring so it would work. There is a wiring diagram for these trucks out there.(http://67-72chevytrucks.com/vboard/showthread.php?t=185665). So..if you can get back to stock...you can easily rewire to work with a 10si.
Jason Banks is online now   Reply With Quote
Old 02-21-2015, 12:16 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
check out this link.
........http://67-72chevytrucks.com/vboard/s...d.php?t=417872
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-21-2015, 01:23 AM   #6
smokie
The "single" wire was a SI12.
Old 02-21-2015, 01:37 AM   #7
firefighterchevy
firefighterchevy's Avatar
Just to make it easy to get a 63 amp single wire alternator, Napa new alternator part number is 1N4011SW. No core needed, and its lifetime warranty.
My friends describe my house as the small town used Chevy Pickup dealership.
firefighterchevy is offline   Reply With Quote
Old 02-21-2015, 02:32 AM   #8
CST10
CST10's Avatar
LMC truck has a conversion harness for $19 that is plug and play to go from external regulator to internal regulated alternators.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 02-21-2015, 02:34 AM   #9
smokie
Truck doesnt have the old regulator in place
Old 02-21-2015, 02:37 AM   #10
smokie
Thanks! Trying to get a little higher amperage though.
Old 02-21-2015, 03:27 PM   #11
RichardJ
How much do you think you need?
37Amp ex reg alt = AC, HEI, 2 elec fans. trailer brake controller, CD player w/bluetooth.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-21-2015, 03:35 PM   #12
smokie
Went with a single wire 63amp meant for a 78 camaro
Old 02-21-2015, 10:27 PM   #13
smokie
14.35 volts at the battery while at idle.
