1964 Fawn interior paint code??
Anybody know the PPG paint code for interior fawn metallic? The old code 22151 seem to be obsolete now. I’m not really wanting to go with a Nissan or ford color.
Everything I've found keeps coming up with that 22151
You can find me on Instagram @neveno_cten |
![]() Join Date: Mar 2005
Re: 1964 Fawn interior paint code??
Call your local automotive paint store and see if they have the mix chart for that code on file. If not, they can call the vendor and get it. The only reason why it might be obsolete in the current charts is that it could be an enamel code, and that stuff is really hard to get nowadays. A lot of vendors have dropped a lot of their old enamel codes.
You can always take one of your original factory painted parts, like the ash tray, door panel, or glove box to the paint store and they can match it up. In the past, some guys used 1990 Honda Laguna Gold base/clear, and had good results. I went through my notes, and came up with this info: Med. Fawn 60% gloss DuPont 9171-L, Ditzler DL-22571, Rinshed-Mason 65B84 Dark Fawn Zero Gloss Du Pont 9202-L, Ditzler DIA 22568 Light Fawn? 60% Du Pont 9170-L, Ditzler DL22569 Medium Saddle 60% Du Pont 4626-L, Ditzler DL-22570, Rinshed-Mason 65B83 Dark Saddle Zero Gloss Du Pont 9199-L, Ditzler DIA-13010 The Fawns are same in '64 and '65. The Saddles are from '66. Hope this helps!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
There is a tutorial some place on this site that I can’t find. From my notes interior paint code match is 2003 Nissan sunlit sand, code EVO-29003 sprayed with 50% reducer and 15% hardener. It matched my interior very well.
![]() Join Date: Aug 2008
try tri city paint in san diego they sell the right color and it is laq. paint
To bad its not sold in spray cans for touch up.http://www.oldchevytrucks.com/cart/i...int%2FInterior
![]() Join Date: Jun 2011
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
| Bookmarks |
