Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-21-2015, 07:15 PM   #11
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Re: 68 GMC 4x4 Suburban build up
Originally Posted by LockDoc View Post
On the clutch do you mean that the pedal is on the floor? The pressure plate doesn't normally stick unless it goes over center. The clutch disk is what sticks from sitting and in that case it just won't release when you push the pedal down. The pedal still works as it should.
LockDoc
I can press the clutch down and it stays there unless i pull it back up
Thanks!
68SWB4x4 is offline   Reply With Quote
