Does the Transmission Cross Member Come Out?
Guys on a '74 GMC 1/2 ton V8 350 Muncie SM465 4spd is it possible to remove the transmission cross member out of the frame rails in order to paint it?
Mine does not look like there is another wiggle room to remove it, is there some sort of trick. This is with the cab and bed on the truck still, transmission and drive shaft removed. Thank you Greg |
#2 | |
Re: Does the Transmission Cross Member Come Out?
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
#3 | |
Greg, I wonder if your frame rails are twisting a bit, making the the crossmember a tighter fit then it would otherwise be? If you think so, you could take some pressure off by jacking a bit under the front two body mounts.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
Yes, they come out.
#6 | |
If it is that tight i would trim a bit off each side.... say a 1/4 inch
| Bookmarks |
