Old 02-17-2015, 10:55 PM   #1
tyler_lay
WTB 4x4 swap parts
what to buy parts to swap my long horn to 4x4 i have axle and springs i need shackles and hangers as ps box and arm thanks
tyler_lay is offline   Reply With Quote
Old 02-18-2015, 09:03 PM   #2
offroden
Re: WTB 4x4 swap parts
I think I have them off my blazer. Front only?
offroden is offline   Reply With Quote
Old 02-18-2015, 09:37 PM   #3
tyler_lay
thank i have a set here in town ill let you know if i still need them
Old 02-19-2015, 12:25 AM   #4
Ironhorse
Ironhorse's Avatar
I have a 4x4 P/S gear box with the pitman arm still installed. Have not used it myself but seems to have good seals with no leaks and the pitman arm responds well when the shaft is turned. One broken mount bolt but should be easy to drill and easy out. Also has the original high pressure and low pressure return line. Asking $60 plus shipping, let me know and I can post pics.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-19-2015, 12:28 AM   #5
tyler_lay
plz do
Old 02-19-2015, 02:39 AM   #6
DLTruck1973
I have every piece you will need for this swap.
Front spring/core support hangers are $40.00 each
Front bump stops with brackets are $20.00 each.
Front spring hangers (rear position, cast piece that shackles bolt to) $20.00 each
Front spring shackles with bolts $12.50 each
Engine cross member $75.00
Trans/transfer case cross member $65.00
Small transfer case mount (bolts to frame) $45.00 complete with rubber and bolts.
Rear spring hanger (front position) $40.00 each
Rear bump stops with brackets $20.00 each
Rear spring hanger (rear position) is $45.00 each
PS pump with brackets, hoses, gear box and steering arm $125.00.
All prices plus shipping.
Let me know. I have nice clean parts.
Thank you,
Thomas
DLTruck1973 is offline   Reply With Quote
Old 02-19-2015, 01:01 PM   #7
Ironhorse
Ironhorse's Avatar
tyler, pics of the gear box with the 4x4 pitman arm attached. One broken mount bolt should be easy to drill and easy out. Seems all seals are good, am including the original press. and return hose merely for comparision for when buying new to match correctly. I would not use these as new hoses aren't that much $$. $60 plus shipping as mentioned. I am in Kansas about 30 miles south of Wichita, not sure where Ramona, Ok is but using UPS for shipping should not be too bad. Let me know if interested and I can figure a shipping quote. Thanks,
Wellington, Ks
Old 02-19-2015, 11:48 PM   #8
engairuph
I have a 4x4 sway bar complete for $50 plus shipping
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 02-20-2015, 12:22 AM   #9
tyler_lay
Ironhores I'll be up ur way Sunday I'll take the box what's the address and a good number
Old 02-20-2015, 08:16 AM   #10
Ironhorse
Ironhorse's Avatar
tyler, will be out of town Sunday. Sending you a PM.
Wellington, Ks
Old 02-23-2015, 05:24 PM   #11
Ironhorse
Ironhorse's Avatar
tyler, still interested? Never heard from you via PM. ??
Wellington, Ks
