Old 02-26-2015, 12:08 PM   #1
WarMonger
WarMonger's Avatar
engine number
So i have this 350 motor. I want to find out what year it is from. Where would I look on block to find some numbers? I believe it is out of a late 70's, but not sure.
WarMonger is offline   Reply With Quote
Old 02-26-2015, 12:19 PM   #2
Saclandman
Saclandman's Avatar
Re: engine number
Casting numbers are located at the back of the block on top, behind the drivers side valve cover. There's also a pad in front of the passengers side valve cover with some numbers stamped which also give you info on the engine.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 02-26-2015, 12:32 PM   #3
geezer#99
geezer#99's Avatar
Re: engine number
Look here!
http://www.mortec.com/
Or here!
http://www.nastyz28.com/decode.php
geezer#99 is online now   Reply With Quote
Old 02-26-2015, 12:33 PM   #4
67 cst swb
67 cst swb's Avatar
Re: engine number
Also, the Date Casting numbers are located at the back of the block on top, but behind the passenger side valve cover. typically a letter, then 1 or 2 numbers, then a space then 1 more number.
It is best to get all 3 numbers mentioned.
Block Casting Number - Rear Driver Side
Date Casting Number - Rear Passenger Side
Stamp Number - Front Passenger Side Cyl Head Mount Surface, just above water pump mount.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-26-2015, 01:00 PM   #5
enaberif
Re: engine number
The alternator pad number may not be accurate either. The really is no definitive way of knowing what you have.
enaberif is offline   Reply With Quote
Old 02-26-2015, 01:28 PM   #6
WarMonger
WarMonger's Avatar
Re: engine number
Thanks for the info guys.
Old 02-26-2015, 05:57 PM   #7
FirstOwner69
FirstOwner69's Avatar
Re: engine number
Here are pictures of the locations on small blocks from my original 350.
First is the casting number behind left head. Second is the casting date (in this case, November 27, 1968) behind the right head. The last is the engine assembly and application info stamped in front of the right head. The assembly date is November, 30 (it should have been "V1130XD" not "VI130XD", but the person who set up the stamp apparently grabbed an I instead of a 1).
FirstOwner69 is offline   Reply With Quote
Old 02-26-2015, 06:02 PM   #8
WarMonger
WarMonger's Avatar
Re: engine number
pics with the explanation is super helpful. Thanks guys. I love this forum.
