Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-23-2015, 03:10 PM   #301
bL.A.zer90045
Re: 70 Blazer Frame Off
great attention to detail,and TOTAL reincarnation of your "stinky old truck"!!!
how did you go about removing the body from the frame,cherry picker in the rear,attached to???
bL.A.zer90045 is offline   Reply With Quote
Old 02-23-2015, 08:03 PM   #302
IronCanine
I'm trying....
IronCanine's Avatar
Thanks...definitely hope it smells better. The body off was literally a one-man job. Eric did it completely by himself using floor jacks, cherry picker, blocking, and a patient methodical approach. Pretty impressive actually. I had to dig deep to find this pic with the lift points on the rear.
....gotta say, I'm a little nervous about hitting page #13.
IronCanine is offline   Reply With Quote
Old 02-23-2015, 08:29 PM   #303
Chulisohombre
Chulisohombre's Avatar
You do watcha gotta do. I've donr that same method before when changing springs or bushings.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 02-24-2015, 10:13 AM   #304
notchbackgta
Only page 8 for me, so you should be good for a while
notchbackgta is offline   Reply With Quote
Old 02-24-2015, 10:59 AM   #305
IronCanine
I'm trying....
IronCanine's Avatar
Yeah...but for the moment we're page 13 and 13K views...got to get through this quick...I'll try to post more pics tonight and maybe we can blow through asap
Old 02-24-2015, 11:14 AM   #306
notchbackgta
No, I mean I have my post count per page set higher, so your thread is only on page 8 for me, so you have 5 more pages to go before you get there. Just change your count and then you'll be all good lol
I am set for 40 posts per page
Old 02-24-2015, 12:10 PM   #307
IronCanine
I'm trying....
IronCanine's Avatar
BRILLIANT! Life Hack. I feel better already...this build has only taken me 8 pages, it felt fast
Old 02-24-2015, 12:59 PM   #308
bL.A.zer90045
awesome thanks! ill have to put my gbodies in the corner and hopefully tackle this to my 86 this spring.did you use truck bedsides,and did you make the lower inner rocker piece,or cut it off the new inner structure on the new sides?
Old 02-24-2015, 01:20 PM   #309
IronCanine
I'm trying....
IronCanine's Avatar
Not a hundred percent on exactly what you're asking, but what we did was use the new reproduction Blazer bed sides. They are complete with inner/outer/front and back structure. I got mine from South Kentucky Classics...but I know GMCPaul and others have them. Inner/outer rocker, floor board, lower A-pillar, etc are all reproduction pieces that most everyone has and require grafting in. The only straight up fab stuff were little patches or connecting pieces.
Old 02-24-2015, 08:08 PM   #310
IronCanine
I'm trying....
IronCanine's Avatar
A little base in the jams and on the inside of the doors.
Old 02-25-2015, 07:01 PM   #311
IronCanine
I'm trying....
IronCanine's Avatar
Interior chrome got here today. I got lucky on the shipment because the packaging wasn't nearly as stout as I'd like to have seen...those guys don't seem to recognize how hard those pieces can be to come by. Also the end of one of the rear trim strips was bad...they didn't blink about fixing it when I called back. Hopefully it won't be another 10 weeks.
Old 02-26-2015, 10:27 PM   #312
IronCanine
I'm trying....
IronCanine's Avatar
All the interior bits that need to be cleared are cleared. Doors hung...hopefully to never come off again. Tape and plastic had been on for a while...time for a change.
Old 02-26-2015, 10:30 PM   #313
IronCanine
I'm trying....
IronCanine's Avatar
After looking at plastic for so long, I'd forgotten how much I missed this jewel.
Old 02-26-2015, 11:22 PM   #314
simplepeddler
man that is shaping up just fine!
simplepeddler is offline   Reply With Quote
Old 02-26-2015, 11:43 PM   #315
IronCanine
I'm trying....
IronCanine's Avatar
Thanks.
Old 02-27-2015, 10:55 AM   #316
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Just in time for Spring! Where was the chrome work done?
Old 02-27-2015, 11:08 AM   #317
IronCanine
I'm trying....
IronCanine's Avatar
Hopefully...I had it done at a chrome shop in Atlanta. I was going to send it to Tennessee...but that was gonna take a year and a half and be the most expensive part of the truck. The guys I used took a "reasonable" amount of time and were easy to deal with. Though I was disappointed to receive a blemished piece, they were gung-ho to get it back and fixed asap.
Unfortunately, I sent it all out about a week before I fell into your bumper threads. If I had it to do again, I would have definitely sent it all there.
Old 02-27-2015, 05:48 PM   #318
scf100
scf100's Avatar
wow.....looking great ...I need to stop by and see it.....
do you use a shop called like Chrome Brothers in Atl?
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 02-27-2015, 09:35 PM   #319
Chulisohombre
Wow that is looking great. better than new. Should last at least another 40 years +. You are taking so much more time than the factory to get it perfect. Can't wait to see paint and all put back together.
Old 02-27-2015, 10:30 PM   #320
IronCanine
I'm trying....
IronCanine's Avatar
You should totally come by...just give me a heads up and we'll give it the once over. Chrome It was the name, the web address it ChromeAtlanta.com. Mack is the guy's name. Fairly easy to deal with.
Thanks...I can't wait either.
Old 02-27-2015, 10:42 PM   #321
IronCanine
I'm trying....
IronCanine's Avatar
Two things went on today with little more than a clean up that are 45 years old. Fan shroud and glove box latch...and they looked pretty darn good. Amazing so much effort goes into rehabilitating, restoring, refinishing or replacing...and they're like, "just let me keep doing what I've been doing for half a century."
...unfortunately the shroud will come back off (like everything, one step forward, two steps back). It seems when they re-cored the radiator, they made it a 1/4" wider. My return rate on parts seems way too high...and it is muy agravante.
Old 02-28-2015, 09:24 AM   #322
cst 72 blazer
cst 72 blazer's Avatar
great job!
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 02-28-2015, 09:51 AM   #323
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by cst 72 blazer View Post
great job!
Thanks!
Old 02-28-2015, 12:13 PM   #324
mtully79
mtully79's Avatar
That truck is looking great, will be one of the best on the forum.
mtully79 is offline   Reply With Quote
Old 02-28-2015, 12:44 PM   #325
IronCanine
I'm trying....
IronCanine's Avatar
Wow. Thanks...I hope it turns out..but this board makes everybody's build better. It's the proverbial rising tide.
...the one that lifts all the boats, not floods your house
1970, blazer, k5 blazer, restoration, silver
