Old 02-28-2015, 10:06 AM   #1
jabos
scarebird brake conversion bracket
I was wondering if anybody has used the scarebird brake conversion kit?
scarebird.com
jabos is offline   Reply With Quote
Old 02-28-2015, 07:22 PM   #2
71 super
71 super's Avatar
Re: scarebird brake conversion bracket
Have not on a truck but just installed on 66 nova and would use it again. The directions are good and the parts they suggest fit right. Only deviation I made was rotors- they suggested using wagoners and milling hub, used bendix and were straight bolt on. Bendix from summit also cheaper by 30 dollars
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-28-2015, 09:44 PM   #3
dirtyjim
dirtyjim's Avatar
I looked into them before I bought drop spindles.
the only reason I can see to use them on our trucks is if you absolutely have to have off the shelf rotors and do not want drop spindles.
you will spend the same on drop or standard height spindles and cpp 6 lug rotors as you will on the scarebird brackets and the oem 6 lug rotors
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 02-28-2015, 10:14 PM   #4
jabos
Thanks for the input guys
