![]() Join Date: Aug 2001
Did washer pumps all mount to the wiper motor?Z
The washer pump I have is mounted to the firewall kinda behind brake booster. My parts guy said it should be mounted to the wiper motor. When I put a new wiper motor in it did not come with a washer pump on it. Does anyone know if every year of GMC Trucks had them on the wiper motors or is there some yrs that were external as mine is?
its all about the +6 inches
67 - 72 were all stock like that. It was a pretty comon set up at the time.
The washer motor is sold separately but it mounts on the same bracket as teh wiper motor. They are interlinked and coordinated so that the washer squirts intermittantly between blade swashes.
See my other post, asking about why mine is acting funny right now. The motor you have would be an after market one that someone probably put on there to avoid having to dig into the dashboard to get to the OEM one. If you've replaced the wiper motor, you already know what a pain it is to get to. |
Formerly yellow72custom
My stock setup consisted of the wiper motor and the washer pump. There was no washer motor...it ran off the wiper motor.
Replacing the wiper motor was an easy job in my truck, took less than an hour, and didn't have to remove anything besides the gas pedal bracket.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
mine was mounted to the wiper motor. of course it didnt work when i got the truck. i just put a new one in the engine bay and cut the hoses to the old one.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#6 | |
My son, my joy.
I'll be doing this also, only because I want TOTAL control of when and how much wiper fluid gets squirted. I'm a dictator when it comes to stuff like that, ![]() |
#7 | |
I also did the aftermarket pump on the firewall in the engine bay. I tried to rebuild the original, what a pain. Then I said screw it, I don't want this thing leaking in my cab. I too have never looked back.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
