Old 02-27-2015, 09:57 PM   #1
cheyenne402
Brake light switch on 2000 Silverado
My brake lights are inoperable. They work with my trailer brake controller though, weird.
I'm thinking it's the brake switch. Fuses are fine.
How do I change it? Tips,tricks?
cheyenne402 is offline   Reply With Quote
Old 02-28-2015, 12:50 PM   #2
hugger6933
Re: Brake light switch on 2000 Silverado
How about the third brake lamp[CHMSL] does it still work? I think it is not operated off the same circuit as the rear lamps and I know it is in a different wiring harness. I have run into this before and it turned out to be the switch on the column. The customer could not understand why the turn signal switch had anything to do with the brake lamps, but they aren't called a combo switch for no reason. Jim
hugger6933 is offline   Reply With Quote
Old 02-28-2015, 09:55 PM   #3
cheyenne402
Third brake light not operable either
Old 03-02-2015, 04:03 PM   #4
cheyenne402
Fixed. For some reason the switch housing was broken. Biggest thing is getting the clip off.
