Old 01-02-2015, 11:52 PM   #76
99 to Life
99 to Life's Avatar
Re: 1951 Project underway
looks good man, how you like the engine start up? what are those rims, kinda artillery style
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-03-2015, 12:34 AM   #77
bretcopsey
That first start put a huge smile on my face. The wheels are Cragar Soft 8. I have 17x9 front and rear. They are heavy but inexpensive for that size.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 03-01-2015, 03:13 PM   #78
bretcopsey
Slow progress, sub zero temps outside make it difficult to get motivated to work in the garage.
I moved the axle back, then shortened the two pieced mid 90's S10 driveshaft, replaced u-joints and modified the carrier bearing mount under the cab.
My 51 project
Old 03-01-2015, 03:16 PM   #79
bretcopsey
I've also upgraded the rear wheel studs to 1/2" and am working on mocking up the rear discs. I also rebuilt the calipers. Once I get all of this sorted I can figure out shock mounting then routing exhaust...
My 51 project
Old 06-03-2015, 10:36 PM   #80
bretcopsey
I had some time to get the truck out of the garage to get some of the clutter cleared out. I also have the trans cross-member done, the exhaust finished, the rear sway bar mounts done and nearly have the under frame gas tank mount completed.
My 51 project
Old 06-06-2015, 12:23 AM   #81
bretcopsey
Decided to work on the front bumper, original application Cadillac. It was a bit too wide, so started by taking 4" out out of the "spreader bar" in the middle.
My 51 project
Old 06-06-2015, 12:27 AM   #82
bretcopsey
Ended up doubling that to 8" total to get it narrow enough to run on the truck. Next step for this project is figuring out mounting to the frame.
My 51 project
Old 06-07-2015, 10:48 PM   #83
99 to Life
99 to Life's Avatar
looking good
Old 06-20-2015, 10:08 PM   #84
bretcopsey
Decided to tackle something different, so took on the tailgate. I wanted to go for something a little different but didn't like the prices of what the aftermarket has to offer. So I'm building one from scratch.
Tomorrow I'll be adding the inner and outer skins. Then it's on to the hinge and latch mods.
My 51 project
Old 06-20-2015, 10:51 PM   #85
watahyahknow
watahyahknow's Avatar
does the tailgate but up against sumting in the closed position . like against a piece of metal strip welded in the inside on each of the bedsides
you could keep the gate closed with just the latches but i think the rattling will drive you crazy
if you stick some foam of rubber windowstrip on the inside part of the metal strips the gate will have some tension against the latches and whont vibrate and rattle as mush
gate looks realy nicely done maibe you can borrow a beadroller from somewhere and put a bowtie and an edging in the rear panel
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-20-2015, 11:49 PM   #86
99 to Life
99 to Life's Avatar
nice job and good idea/approach. there is alot you can do with a blank skin.
Old 06-26-2015, 11:27 PM   #87
bretcopsey
Not much progress since last post. We've been busy this week with a new purchase.
http://67-72chevytrucks.com/vboard/s...d.php?t=674952
My 51 project
