Old 12-10-2013, 11:44 PM   #76
hookedonchevys
hookedonchevys's Avatar
Re: The Hangover Express
Well I dont think you really have to worry about the subliminal messages Matt.I'd say going LS is sitting quite heavy in my thoughts right now!
hookedonchevys is offline   Reply With Quote
Old 12-21-2013, 11:20 PM   #77
PHAT TONY
PHAT TONY's Avatar
If ya need to ditch the vortech electrics or electrics/motor complete lemme know....
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-21-2013, 11:51 PM   #78
Slammed66
Needs a Big Block
Slammed66's Avatar
He probably will take you up on that,
I heard he's gonna LS swap the burb too
( insert evil cackle )
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 12-22-2013, 12:36 PM   #79
PHAT TONY
PHAT TONY's Avatar
Tee-hee-hee-hee
1972 K10 4X4-Sold
Old 12-22-2013, 01:20 PM   #80
hookedonchevys
Ha ha you guys are funny.Well the plan as of right now Tony is to put the vortec in the burb,buuuuut,stranger things have happened!
1972 c10 long fleet,hangover express
http://67-72chevytrucks.com/vboard/s...d.php?t=600282
1971 2wd suburban
Old 12-23-2013, 07:03 PM   #81
hookedonchevys
Well no actual truck progress,but i did manage to find some time to make a 1.250" die for the pipe bender.Im going to make a 1.500" one also out of the same piece of steel since I only need 1/2 of it for each die.Now I just need to scrounge up some DOM tubing and start bending.When in doubt,add more work for yourself.
1971 2wd suburban
Old 01-18-2014, 12:51 AM   #82
hookedonchevys
Well after alot of scheming and decision making I finally decided to put a LS engine in the ol 72.So I did a bunch of searching around and when I finally got a couple days off work to go for a drive the 2 engines I was hoping for had sold the day before.But luckily slammed66 had some spare stuff kicking around and sold me his 6.0L,a set of L92 heads and an oil pan.Thanks Matt!!!!!
Now I just have to do a major clean up in the garage and I'm going to try to get the engine and tranny set in the frame for mock up purposes.
1971 2wd suburban
Old 01-18-2014, 11:49 AM   #83
Slammed66
Needs a Big Block
Slammed66's Avatar
Mmmmmmmm. Ls power
* subliminal message
You need boost- you neeeeeed booooost -
1964 Short box
1972 K10
Old 01-18-2014, 02:09 PM   #84
AJohn6
Knuckle head
AJohn6's Avatar
Looks great man. You can run a heck of a bead that's for certain.
-Adam
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 01-19-2014, 02:25 PM   #85
hookedonchevys
-Adam
Thanks a lot!Those miller 211 welders are really nice to work with.
1971 2wd suburban
Old 01-26-2014, 09:11 PM   #86
hookedonchevys
Well I finally got a day in the garage again.I got the frame off the sawhorses and bolted up the dropmember again so I can mock up the engine and transmission and start with all the fun stuff!It's about -30c here today so by the time I was done bolting everything up the garage was finally a comfortable temperature.Oh well,thats the fun of northern Alberta,so engine and tranny are mocked up,now I just have to decide what to do next.
1971 2wd suburban
Old 01-26-2014, 09:26 PM   #87
mcbassin
Still Learning
mcbassin's Avatar
I like your decision to go with ls power plant. Looks great sitting in the chassis.
Digging the bender mandrel you made too.
Old 01-28-2014, 12:00 AM   #88
Bomp
Bomp's Avatar
Making progress. What size of tube did you use for the tranny cross member?
Looks good.
Bomp is offline   Reply With Quote
Old 01-28-2014, 03:17 PM   #89
vsoree
vsoree's Avatar
What brand oil pan is that?
Stay blessed not Stressed!
vsoree is offline   Reply With Quote
Old 01-28-2014, 07:51 PM   #90
hookedonchevys
Thanks a lot!Yeah I've been scheming on the LS for awhile now,everything I've researched has pointed in the direction of great power and reliability with minimal effort,so,nows as good a time as any!
Originally Posted by Bomp View Post
Making progress. What size of tube did you use for the tranny cross member? Looks good.
The crossmember is 1.500" tubing.
It is a chevrolet oil pan.I think it is off a newer camaro but not exactly sure since it was purchased by someone else at a swap meet.It does fit very nicely around the porterbuilt dropmember though.
1971 2wd suburban
Old 01-28-2014, 11:18 PM   #91
Slammed66
Needs a Big Block
Slammed66's Avatar
that oil pan is off an e-rod crate engine I was told.
1964 Short box
1972 K10
Old 01-30-2014, 06:25 PM   #92
hookedonchevys
Well after another day of screwing around in the garage I got the rear suspension thrown back in it to make it a true roller again.I also did some humin and hahin over the position of the tranny crossmember.I have the engine sitting at 5 degrees compared to the frame,so I'm thinking I'm pretty close to where i want it.Just gonna have to break down here soon and drill some holes.I did some scheming on where I'm going to mount my fuel tank.Im thinking of making a spacer/mount to place the fuel tank mounts in the center of the frame instead of sitting it on top of the frame rails so I can put some standoffs on top of the frame when I go to mount my box.
1971 2wd suburban
Old 01-30-2014, 10:52 PM   #93
PHAT TONY
PHAT TONY's Avatar
Holy jeez.....
1972 K10 4X4-Sold
Old 01-31-2014, 02:26 PM   #94
afmedic01
afmedic01's Avatar
Nice build you have going. Keep up the good work. Good choice on the LS. I want to put an LS in my project as well, just need to find a good deal on one.
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611258
My build thread:
69 C10 SWB Fleet(under construction)
350/TH350
Porterbuilt Front/Rear Mild Dropmembers
Accuair e-level kit
Coys C5 22x9, Nitto 555 255/30r22
afmedic01 is offline   Reply With Quote
Old 01-31-2014, 03:13 PM   #95
vsoree
vsoree's Avatar
Thanks for the info, I saw an aftermarket oil pan on Craigslist and I thought that was the same kind. Love the build watching ever step
Old 02-07-2014, 11:39 PM   #96
hookedonchevys
Thanks for the compliments on the build guys!!!!
Well got a little progress done on the truck.I went for the 5 hour drive to edmonton and picked up some parts last weekend,3" flow master stainless exhaust kit,fuel pump and regulator,msd box for the LS,and a bunch of other smaller stuff,fuel line fittings and so on.Then today I got to go to the post office and pick up the headers I ordered off ebay a couple weeks ago!!!
They need a couple mods cause they are the camaro ones with that air pump attachment on a couple tubes,or whatever those are,and I'll have to turn one collector a bit but nothing a grinder and welder cant fix.
I also did some work on my transmission mount,I decided to bolt it on the inside of the frame and run 1" solid through the box and welt it on both sides.Enough rambling,heres a couple pics.
1971 2wd suburban
Old 02-07-2014, 11:44 PM   #97
hookedonchevys
And yes,my Dog agrees the headers look great!
1971 2wd suburban
Old 02-12-2014, 11:51 PM   #98
hookedonchevys
No Huge update to post but I did manage to tack in my tranny crossmember mount today,hopefully will get it welded up tomorrow.Cut down the porterbuilt one to mount in between the boxed frame rails.
1971 2wd suburban
Old 03-01-2015, 10:45 PM   #99
hookedonchevys
Well, i finally got back in the garage after quite a lengthy time away from my project. I picked up a plasma cutter and big welder since I want to big my exhaust and well have always wanted one anyway. So I geared up the welder and plasma cutter on the cart for my mig welder. I was pretty happy with how they fit on the bottom of my cart. I just had to do a little modifying to the back and fit my argon and CO2 bottles both on there also. So today I finally cut off the collector on the drivers side header and straightened it out so that it doesn't point the exhaust into the frame, and welded on the v band clamp to the end of the collector. Found out the hard way though that the big does not like any gap when your trying to weld something that thin. Oh well I'll have lots of time to get the tig dialed in by the time I finish that exhaust.
1971 2wd suburban
