05-18-2014, 12:38 PM | #51 |
Re: Ls alt wiring
Pulling out the old thread shovel and digging this one up. My 76, with a 2002 4.8l swap, shows the brown wire 16brn25 going from the alt to the bulk head connector then to the instrument cluster but it also splits to the headlamp switch. I have a volt meter in my dash. It appears that I can just hook the original brown wire to B+?
I don't want to mess with the factory 2002 wiring by tapping into the brown wiring off of the alternator. Anyone have a suggestion? thanks.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
05-19-2014, 04:35 PM | #52 |
Re: Ls alt wiring
So I fired it up from the key for the first time and my voltmeter on the dash was reading about 13.5v. I did not hook up the brown wire from the original alternator to anything. Any thoughts as to what I should do with this wire? Thanks
05-27-2014, 12:46 AM | #53 |
Re: Ls alt wiring
I was actually missing my connector for the alternator. mine is a two pin there is a brown wire that comes out and should go to your green pcm connector pin 15, as per my engine wiring guy. Not sure if this helps or not.
Trying to get thru my LS swap |
03-02-2015, 12:16 PM | #54 |
Re: Ls alt wiring
I have the blue and red pcm connectors and I am still a little lost on this brown wire and what to do with it.
03-02-2015, 12:21 PM | #55 |
Re: Ls alt wiring
What alternator are you using? Camaro, Vette, or Truck?
'55 3200 283 4 speed '68 Pontiac Firebird Poncho powered with a 6 speed |
03-02-2015, 12:26 PM | #56 |
Re: Ls alt wiring
Sorry, I have a 2002 4.8l in my 1976 SWB. The 2002 appears to be "self contained" as far as what I need to do with integrating the 1976 and 2002 harnesses. I also have a question as to the blue oil pressure switch wire from the '76 harness as well.
03-02-2015, 12:45 PM | #57 | |
Re: Ls alt wiring
As for the blue wire for the '76 oil pressure gauge, you need to mount the '76 oil pressure sender in either the oil pressure sender spot of the 5.3, or you can drill and tap the block off above the oil filter, then just hook the blue wire to it and you're done.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-02-2015, 12:53 PM | #58 | ||
Re: Ls alt wiring
Assuming that you have a truck alternator this is what you need to do - Copied from what I posted on the first page: One wire goes straight to 12 volt (Pin C), the other MUST have resistance, ie gen light or resistor (Pin B).. However as LS1Nova pointed out you can easily just leave the two wires connected to the PCM and let the PCM worry about the Alternator Quote:
'55 3200 283 4 speed '68 Pontiac Firebird Poncho powered with a 6 speed Last edited by Pzary3233; 03-02-2015 at 01:02 PM. |
03-02-2015, 01:24 PM | #59 |
Re: Ls alt wiring
On my oil pressure issue, I also have a mechanical connection. I never had an engine in this truck so I am unsure how it was originally hooked up. Was there originally two hook ups on a "T"?
03-02-2015, 01:51 PM | #60 |
Re: Ls alt wiring
Matt make another thread for your oil pressure issue so we don't bog down an alternator thread for it.
Oil pressure could have either been a mechanical or electrical connection depending on the vehicle's gauge. Go with what you have and you will be fine.
03-02-2015, 07:52 PM | #61 | |
Re: Ls alt wiring
As for a mechanical oil pressure gauge, check my build threads, at least one of them shows how to easily fix that with a drill and a tap. Super simple.
03-02-2015, 10:54 PM | #62 |
Re: Ls alt wiring
Thanks guys, I really appreciate the advise. I am so close to ripping it around the block I can taste it.
03-08-2016, 01:25 AM | #63 |
Re: Ls alt wiring
I know this must be getting very annoying to have to keep answering slightly different questions of the same topic... However while reading this thread it never was explained very clearly how to connect a (ex: ) 2004 silverado 145amp alternator to c10 wiring harness with a carbureted LS engine instead of FI. I know the red power wire which connected to back lug of the original delco alternator is connected the same, and I know there's one more wire that needs to be connected to the stock c10 alt. Harness, and I do know that when going carburated you need a resistor inline to that said wire, but which terminal on the Delphi plug and which color wire from the c10 harness go together? I bough Holley's LS swap alt. Pigtail which has the resistor already and it's positioned for the "L" terminal on my alternator, is that correct?
03-08-2016, 07:44 AM | #64 |
Re: Ls alt wiring
You all are just so smart. Thank you, I and many others to come appreciate it!!
03-08-2016, 10:16 PM | #65 | |
Re: Ls alt wiring
What concerned me was that I just spent all this money to upgrade my truck, but would also be running 2 electric fans, and 1 electric fuel pump off of my battery and possibly have too high of an amperage draw and too high of an amperage output alternator and an undersized wiring harness that was almost 50 years old. Rather than taking the chance of being stranded or burning my truck down I switched to a painless wiring harness and that kit comes with the stuff you need to properly wire a 105 amp (max allowed) type CS130D alternator and make your electrical system operate off of the power output of the alternator and properly sense the voltage draw of your electrical system and charge the battery as needed. I also had to buy the plug, #30705, from Painless for the alternator so that it could be properly wired. It took several phone calls to Painless to get the right person that understood all of this and knew what I was asking, as well as what they were talking about. Also, their wire harness instructions were being revised, and at the time I downloaded this particular wire harness instruction manual from their site it had not been updated and it did not explain anything related to the newer style CS130D alternators, but the one I received in the box with the harness was the correct set of instructions and described all of this to the letter...... I also tried to talk to Holley technical because they sell a LS alternator and plug, but I could never get the right person that actually understood me or their product on the phone to help me understand how to wire it up to an existing harness, therefore I chose to go thru the effort of swapping the harness out and do not regret it. It's worth your time to read up the explanation of how a proper charging system works on www.madelectrical.com |
06-30-2016, 03:16 AM | #66 | |
Re: Ls alt wiring
06-30-2016, 08:25 AM | #67 | |
Re: Ls alt wiring
I answered your question just a few posts up:
DO NOT USE THE C10 WIRING it is too old and small to handle the amperage! Sounds like you have a handle on that part. You may use the idiot light wire (because you do need an idiot light to make this alternator charge). Simply find the wire that is connected to your idiot light in the dash and follow this post and you'll be charging in no time! Quote:
06-30-2016, 08:26 AM | #68 | |
Re: Ls alt wiring
06-30-2016, 04:15 PM | #69 |
Re: Ls alt wiring
Thanks guys. Checked the wires for 12 volts running. Wired it up with the resistor as shown and she's charging. One more thing to cross off the list.
10-02-2016, 11:32 PM | #70 |
Re: Ls alt wiring
sorry for reviving this thread but Im stumped..
I just finished putting a 2002 lq9 in my 72 c10 and I'm having and issue with the ammeter gauge. It worked fine with the old 250 6 banger but ever since I put the new motor in the gauge is always reading towards the charge side of the gauge and once the electric fans come on it pins all the way to charge side. The instruction manual that came with my harness (painless performance) said to add a 5 watt resistor to the brown wire and so thats the only modifications that I've done to the alternator wiring. Im afraid that I am going to hurt the gauge by always having it pinned out... Any ideas on why the gauge is always reading towards the charge side? Thanks ahead of time...
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 |
06-05-2018, 09:37 AM | #71 | |
Re: Ls alt wiring
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-05-2018 at 09:53 AM. |
06-05-2018, 03:49 PM | #72 |
Re: Ls alt wiring
2006 Schematics: http://www.lt1swap.com/pictures/03to07schematics/2006/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-05-2018, 09:29 PM | #73 |
Re: Ls alt wiring
2 wires to the alternator, 2 wires to the battery, 2 wires to ground, 1 wire to serial data port - BOOM!!, it works!!!! Thanks Clinebarger!!!!
01-10-2020, 02:12 PM | #74 |
Re: Ls alt wiring
Reviving this thread. Can Hart Rod or Clinebarger elaborate on this? Did I miss something on this tread that you both figured out. Can you post a diagram?
