Old 03-02-2015, 12:35 AM   #1
LS1Impala
Inner Fenders with 5/7 drop?
I have a 68 C10 with a 5/7 drop...currently it does not have inner fender but I am looking to add some. Does anyone have stock inners with a 5/7 drop?
1968 C10 5.3/4L60E LS6 cam and a 3600 stall
1968 Camaro 6.0/4L65E T76 turbo 9"
1960 Impala LS1/4L60E all stock cruiser
LS1Impala is offline   Reply With Quote
Old 03-02-2015, 02:07 PM   #2
SCOTI
SCOTI's Avatar
Re: Inner Fenders with 5/7 drop?
5/7 w/inner fenders is no problem depending on tire OD. Less than 8" wide wheels w/under 28" tire height will minimize contact. The wider things go or the taller the tire & it will likely buzz @ the extreme inside/outside.
It will definitely occur w/more drop.
5-6" front drop; ~8" rear drop; 27.5" OD 15x6.5" wheel & no rubbing under 'normal' daily driving conditions:
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-02-2015, 03:44 PM   #3
LS1Impala
Thank you for the response! I hope to get them on soon!
Old 03-02-2015, 05:00 PM   #4
SCOTI
SCOTI's Avatar
Worst case, there are aftermaket alternatives.....
Hills Rod & Custom
http://www.hillsrodandcustom.com/?page_id=19
Slosh Tubz
http://www.sloshtubz.net/products.php
For 67-72's, Hills look more OE.
For 73-87's Slosh Tubs are the only choice to date.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-02-2015, 07:01 PM   #5
Mike C
Mike C's Avatar
I have 4.5"/7" with 235 55 17 on 8" wide rim with 4.5" backspace and have no rubbing issues. That extra 1/2" might do you in, but probably not. Especially with a 7" rim.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-02-2015, 07:07 PM   #6
SCOTI
SCOTI's Avatar
I've seen your info before on similar subjects as I bet you've seen mine. Do you have a reference pic for people to gauge your set-up when they're researching this stuff?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-03-2015, 11:25 AM   #7
blazer2007
Could you post your tire sizes,looks like a nice combo
blazer2007 is offline   Reply With Quote
Old 03-03-2015, 12:06 PM   #8
SCOTI
SCOTI's Avatar
In that pic, the fronts were 215/75's & rears were 255/70's. Fronts eventually went to 225/70's because I wanted matching tread (BFG Radial T/A's).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2015, 12:48 PM   #9
specialtyretail
So,, what else you got???
specialtyretail's Avatar
SCOTI. love the looks of that truck....
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 03-05-2015, 01:49 PM   #10
SCOTI
SCOTI's Avatar
Thanks..... It was a cool truck. 6cyl w/3 on the tree. Tugged cars/trucks around on my trailer pretty well too so it was very functional.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2015, 10:35 AM   #11
Mike C
Mike C's Avatar
Yes. Just trying not to hog everybody's threads with my junk! 2.5" drop spindle ECE disc conversion, 2" drop spring with stock length KYB front shocks. 7" drop in rear with DJM flip kit and CalTrac bars. Same stock length KYB front shocks moved to alternate position on leaf spring rear upper shock mount. Removed factory pads from above bump stop mount on axle housing and mounted urethane bumps on frame that came with DJM kit. No notch.
235 55 17 on 17x8 4.5" Summit Legend wheel in front (27" tall). 275 55 17 on 17x9 5" bs in rear same wheel (29" tall).
44 Willys MB
52 M38A1
64 Corvette Coupe
