Old 03-02-2015, 12:57 AM   #1
Motherfrog402
Motherfrog402's Avatar
Pump to Carb Fuel Line
Does anyone know if the 67-72 292 pump to carb fuel line will fit '73-newer trucks? I've looked everywhere for one but can only find pre-'73 line. I see no reason why it wouldn't, but I'd like to be sure.
Thanks.
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
1972 C10 Suburban - SOLD
White/Medium Spruce Metallic/White
Avocado Highlander Pkg
402/TH400
3.08:1 open
Motherfrog402 is offline   Reply With Quote
Old 03-02-2015, 05:36 AM   #2
andrewmp6
Re: Pump to Carb Fuel Line
I think it should but have no idea really.
Old 03-02-2015, 11:22 AM   #3
bdiamond
Contact Inline tube. They can manufacture anything you need. http://www.inlinetube.com/
bdiamond is offline   Reply With Quote
Old 03-02-2015, 11:23 AM   #4
Motherfrog402
Very familiar with them...good Jeep products. I'll try them, thanks.
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
402/TH400
3.08:1 open
Old 03-02-2015, 03:15 PM   #5
greg64
greg64's Avatar
Hey Fred, as long as both engines were using Rochester carbs, the fuel line ought to fit. The pumps are in the same place on all 292s (interestingly enough, a different place from the 230/250).
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-02-2015, 04:41 PM   #6
Bigstevex4
Bigstevex4's Avatar
I just use rubber fuel line. I know Not as safe But you can run it easier away from any thing hot and i think it helps keep fuel from getting hot adding to vapor lock.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 03-02-2015, 11:08 PM   #7
Motherfrog402
That's what I was thinking too. Makes me wonder why they label it '67-'72... I'll get one and report back.
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
402/TH400
3.08:1 open
Old 03-02-2015, 11:11 PM   #8
Motherfrog402
But if the hose happens to rub on something, or it fails from ethanol (which I've seen happen), you run the risk of fire, and I have an aversion to blowing up.
Fred
1974 C-20 Fleetside
White/Crimson Red
292/SM465
4.10:1 open
1976 AMC/Jeep CJ-5
Lime Green
258/T150
3.54:1 open
402/TH400
3.08:1 open
