LS in a AD guys
Love to know what you used for Radiator hoses.
I cant find a lower that will fit except the ugly $$ flexible ones with the big green stripe |
![]() Join Date: Aug 2012
Re: LS in a AD guys
What are you using for the thermostat housing? I think the stock housing on most/all LS variants ends up with the water neck pointed pretty much straight into the inner fender, which makes fitting a hose challenging. I haven't fit hoses yet, but I did pick up a swivel-neck thermostat housing from Street & Performance. This allows me to point the water neck straight down directly at the radiator outlet, which should make hose fitment a lot easier. Here's a pic showing the housing installed:
Build Thread: "Marvin" (1953 3100) |
Re: LS in a AD guys
I used a swivel neck as well. Mine was the Mr. Gasket one. This allowed us to point it down and it was pretty much a simple 90 degree bent hose that ended up working out I think. Nothing crazy.
Re: LS in a AD guys
torchlight
v nice pict sir ........clean setup |
Re: LS in a AD guys
Problem I have is the AC unit I am using. The swivel will not work due to the thickness and straight out would hit the belt.
Re: LS in a AD guys
sorry for the big pic.....on my phone
Re: LS in a AD guys
Nice looking setup Iceburg. Hope that constant ticking of the header on the passenger side frame doesn't drive you nuts. Sure looks close.
#8 | |
Re: LS in a AD guys
Kicked it over one hole on the mounts after the pic.....about 1/2" now |
Re: LS in a AD guys
Hey Eagleuh1....do you know John Schaublin from Russelville?
Re: LS in a AD guys
I would look at having 1 1/2" exhaust pipe bent and use a straight piece of hose to connect the water neck & pipe. Note that you MUST have a bead pressed or welded onto the pipe to keep it from leaking.
You can also find a lot of hose connectors (splices) and silicon / rubber bends in Speedway Motor's catalog. I also used a selection of splices & OEM hoses I found on Summitracing.com : Summit has a huge selection of cheap OEM hoses that you can sort by diameter, length, curves, etc and between the two suppliers even a knuckle dragger like me can plumb a radiator. EDIT: I thought about it a bit more and one supplier I used actually has a *TON* of parts that might help you here. I had great experience with them. Click here for a link. Siliconeintakes.com
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. Last edited by yossarian19; 02-10-2015 at 11:47 PM. |
Re: LS in a AD guys
Here is the one I used. From the picture you posted it looks like it should work. I don't have any picture handy though.
http://shop.mr-gasket.com/cooling-sy...swivel-30.html |
Re: LS in a AD guys
I also used an s&p pointed straight down, not out. It works well. I've only driven a few blocks at a time so far though.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
Re: LS in a AD guys
Thanks for the links
Re: LS in a AD guys
Here's mine. Napa part # 8661 after some trimming.
![]() Another angle: ![]() Here's what was trimmed from the top and bottom to fit perfect: ![]()
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#15 |
Hollister Road Co.
Re: LS in a AD guys
#16 |
Re: LS in a AD guys
Napa #9053. Radiator is a 19x24" dual pass.
![]() ![]() This was the candidate pool I brought home before I found the ones that worked. Took my bent up TIG wires to the store and matched it up with hoses of the correct size. ![]()
#17 |
![]() Join Date: Jul 2012
Re: LS in a AD guys
Thank you Blue Jeep!
#18 | |
Re: LS in a AD guys
#19 |
Hollister Road Co.
Re: LS in a AD guys
Thanks for the hose numbers, Looks like they will fit with a little tweaking. I'm using a Walker radiator made for an LS and they look to be almost a perfect fit. You saved me hours, much apreciated
#20 |
Re: LS in a AD guys
I'm happy to help!
#21 |
Re: LS in a AD guys
Iceburgh, no, name doesn't sound familiar. Any more clues.what does he do for living? Jim
#22 |
Re: LS in a AD guys
He drove a show truck for Meguiars for a long time then one for Suzuki.
Blue jeep thanks the numbers worked out great. I am all set up. Thanks again |
#23 |
It's alsways something.....
![]() Join Date: Nov 2008
Re: LS in a AD guys
Sub here for future ref on hoses. Thanks for posting this helpful info
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#24 |
Hollister Road Co.
Re: LS in a AD guys
I wanted to add that I couldn't use the other lower hoses above without a new water neck. The NAPA 708 hose which is listed as an upper and lower fit with the stock neck and just trimming the hose a bit. it fits more GM cars and truck than I can list mostly 6 cylinder and early V8
