200-4R TV cable
So I've had little luck finding a TV cable adapter for my BBC that works with the linkage the big block trucks have (which is short to clear the intake or everyone I've had uses a manual trans carb or has been cut).
Anyway, just a random question: if the TV cable is set correctly so that it shifts at the right point, can it be wrong? I understand the pivot point may not be linear (might be progressive) but it feels like if it were too 'loose' it'd shift late and too 'tight' it'd shift early, since shift point is determined by TV pull, or it sure seem like it when you've got it wrong, anyway. Do you think this theory holds? Or could you have it where it shifts at exactly the right RPM and load, but it's actually still wrong and your pressure is wrong and you're going to grenade it? Thanks! Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() Join Date: Oct 2009
Re: 200-4R TV cable
Dave, you've probably already seen this stuff, but bowtie overdrives is a good source for all things tv cable-related. http://www.tvmadeez.com/
#3 | |
Re: 200-4R TV cable
Their kit needs the Q-jet linkage that extends down more, and can't be used without it. It makes sense to ME that we'd never have the extended linkage style because you either got a stick or a TH400. TH400 just has electric kickdown, right? No cable? I can't think of any application for this truck where a kickdown CABLE was used, at least not offhand.
Re: 200-4R TV cable
Here's the carb as I got it straight off the truck. Now it's possible the PO cut it, and it sure does look rough for a factory part, but that's where it ends on mine. If anyone can find a big-block auto to take a photo of, which shouldn't be too hard, that'd answer it for me.
Thanks! Dave
![]() ![]() Join Date: Sep 2008
Re: 200-4R TV cable
I am getting ready to take my big block 71, with 700R for its first drive this week, depending on the snow and ice..
I ended up using a small block carb, set up for turbo 350, and using the big block jets. (tagged the original carb and put it on the shelf) I had to use a 3/4 inch spacer to get the mechanism to clear the intake. My tranny guy ordered a bracket for the TV hookup to the accelerator bracket. I will try to get some pics and part number for the bracket for you this week. Larry
#6 | |
Re: 200-4R TV cable
horsepower junkie
Re: 200-4R TV cable
if the cable is too "tight" it will shift late and harder,too "loose" and it will shift early and softer..if you are happy with the RPMS and MPH your shifts are happening,and the shifts arent slipping or feeling mushy...than its all good...if you dont have enough TV pressure,it will be in 3rd gear before you get thru an intersection....the other part of the cable being "right"..is when your cruising at 50 in OD and lockup,does it kick down properly?
67 ![]() 71 olds cutlass "S" mom bought new..12.30s@113MPH |
#8 | |
Re: 200-4R TV cable
I think you are going to have to go with a different carb or a different primary throttle shaft with the hang down part for the detent cable for a T350. You could just go with the shaft if you want to keep your carb numbers correct. Good time to put in new throttle shaft bushings, but I expect you already did that knowing you. If you don't clear the intake, you will need a spacer. Or maybe you could just do some minor clearance on the new shaft/carb I don't know if it's possible but I'd try before I put on an unsightly spacer. Do you have a "divorced" choke? That might put the kibosh on a spacer. Maybe try a small block Quad for an automatic on first to see if it clears. Maybe you could modify something like this and make it clear the intake on your present carb (I know the geometry is critical). http://www.summitracing.com/parts/tc...FYOSfgod_wgAFA Or this. http://www.jegs.com/i/JEGS-Performan...57301/10002/-1 Also, the 2004R never came behind a 4bbl spread-bore carb, that I know of. The throttle valve spring in the valve-body may not be calibrated for the Quadrajet, it might be calibrated for a 2bbl throttle body. I know on 700's they offer a different throttle valve spring for the Quadrajets vs the throttle bodies. What happens is the carb you have is still opening the primaries as the secondaries start opening, thus a non-linear throttle progression vs a linear throttle progression on the fuel injected engines. Maybe your trans builder/supplier already compensated for this, just adding info. |
#9 | |
Re: 200-4R TV cable
That being said, you had better try as hard as you can to duplicate factory geometry on the carb linkage. And as I mentioned in the other response, you may have another calibration issue inside the trans. Are you saying that right now you have it shifting right with the present set-up? |
Re: 200-4R TV cable
As a suggestion if it was me i would get a tbi truck and rob the throttle body off of it and duplicate everything, cable angle, pivot location etc. This would require cutting off the linkage from the tbi and attaching it to your carb. About 10 years ago i stumbled on the best article to address this. It had to do with a plumb bob hanging down through the center of the throttle shaft. Your throttle should be 33% open when the center of the stud is down at the 6 oclock position, leaving 66% to be pulled forward till wide open throttle. It also stated that the tv cable didn't pull linearly, very sensitive the first 33%, less sensitive the last 66%. It also stated putting a pressure gauge into the trans body and at curb idle fully warmed up, throttle completely closed, i believe the ideal pressure was about 100 psi. I also believe this was throttle valve pressure. I'm only stating this as it was difficult to find that info before, so take this as a fill in guide until it gets straightened out. I went through all of this when i put a carbed 5.7 /700r4 in my 68 c10 years ago before the ls change. I went to the junkyard and found an 1981 qjet 700r4 combo and robbed the throttle shaft out of it and put that into my 70's vintage qjet. I remember the final frustration was the cable attachment bracket. Cable was perfectly horizontal and trans didn't shift right. It worked correctly when i robbed a tbi truck bracket, as the cable was slopped uphill. Easier to find 90's parts in the rusty north than trying to find 70's parts. Good luck Brian F.
#11 | |
Re: 200-4R TV cable
#12 | |
Re: 200-4R TV cable
Is that the one that did not work out for you? Did the 700R4 that you used come out of a car with a Quadrajet or a 2bbl? If it was a 2bbl or a TBI transmission, did you change the spring on the throttle valve to the proper one for a Quadrajet? All the 700 swaps I have done were from T350's. They all had Quadrajets, and we simply put the 700 TV cables on the 350 cable brackets. The transmissions we used were off either TBI or TPI, so we put the GM recommended springs in the throttle valve in the trans to match the Quadrajets. One was a TBI trans into a TPI car, we did not change the spring in that one. They all worked like a charm. I just don't know if you can get that spring for a 200. |
#13 | |
Re: 200-4R TV cable
Re: 200-4R TV cable
Mechanicalman, your tv spring question i now remember was addressed in the rebuild as i think it was a spring inside a plunger mod maybe? I remember getting my wife to slowly step on the gas pedal as i went over the tv plunger travel inside the trans. Mad that i couldn't get it right i found the info, installed the bracket and travel was correct.
#15 | |
Re: 200-4R TV cable
#16 |
![]() Join Date: Aug 2008
Re: 200-4R TV cable
I have seen more cars with 200 4 r trans and 4 barrel carbs that 2 barrel. Monte Carlo (SS and non SS with 305 engine) olds cutlass with 307 ( i dont think ive ever seen a 307 2 barrel) my mom had an 83 olds 88 with a 307 4 barrel and 200 4r, neighbors mom had and 84 olds 98 with same engine and trans.
#17 | |
Re: 200-4R TV cable
Really, that would have been a good lead in for you to help with people needing assistance with this like the OP. Thanks for the info, now I've used it for my lead in. BTW, all the throttle body fuel injected 2004Rs were 2 bbl. I worked at Cadillac from 83-89 so I was not tuned into the carb ones. We both learned something here it's a win-win. ![]() |
