Old 02-27-2013, 05:51 PM   #1
byates2
byates2's Avatar
Tach Filter????
So ive seen that i need a tach filter because i am running an HEI on an old style tach. I'm trying to figure out how to wire it on. Amyone know??
I'm guessing the blue wire goes into the pink clip, but where do the tach filter wires go??
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 02-27-2013, 08:35 PM   #2
JimKshortstep4x4
Re: Tach Filter????
Is your tach an original or is it a repop?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-28-2013, 08:34 PM   #3
byates2
byates2's Avatar
Re: Tach Filter????
Its a repro
Old 03-05-2013, 10:45 PM   #4
byates2
byates2's Avatar
Re: Tach Filter????
Can anyone help me?? Do the reproductions need the tach filter. I have HEI. Since i dont have a coil, where would the wire that needs to hook up to the negative side of the coil go?????
Old 03-05-2013, 11:28 PM   #5
Husker
Husker's Avatar
Re: Tach Filter????
I would not think you would need one.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-06-2013, 12:24 AM   #6
jocko
jocko's Avatar
Re: Tach Filter????
My gut feeling is that you do need one (tach filter) - then I found this on a chevelle forum I was looking at on this subj and it seems to back up that feeling (the poster at least "sounds" like he knows what he's talkin about... )
"You need to install a tach filter between the tach wire and the distributor. The waves that an HEI distributor puts out cannot be properly read by MOST analog factory tachs. I have heard (but never personally seen) of very few instances where a tach worked without any modification. Anytime someone buys a harness from us that is modified for HEI, we typically inform them that they will need to put a tach filter in line on that wire. Accell and Mallory both make a piece, but most any Camaro or Monte Carlo or other HEI vehicles from the 70's/80's will have a tach filter on them if they are equippped with a factory tach. A junk yard trip is possibly in order. They look like a condenser with wires coming out of each end....1 to the coil/distributor cap, the other to the tach wire. They are a plug and play deal. They show up on ebay pretty regularly and can usually be bought for 35-50 bucks. Good luck"
Here's the link to the whole discussion http://www.chevelles.com/forums/showthread.php?t=312599
As for the wiring - I am reasonably sure that the tach filter (Classic Truck Parts sells them: Part #24-736 $26.95, but you obviously already have one in th epic there) simply fits inline at the three connection points shown in the wiring diagram - I think.
The pink wire and terminal you show in your picture is a piggyback - i.e. a means of plugging into a power lead on your fuze box without losing the current purpose of the connection (i.e. 2 wires (one for your tach, and one for something else that is already there) into one hot connection). So, without seeing the whole wiring setup you have (and had), I'm not real sure about what that particular wire is used for. Sorry - not a lot of help on the wiring part of your question - but I am pretty sure you need a filter.
Old 03-05-2015, 04:20 PM   #7
Photoferg
Photoferg's Avatar
Re: Tach Filter????
This post is over a year old? I am faced with same question today. I did not see an answer to original question? Any help?
Photoferg is offline   Reply With Quote
Old 03-05-2015, 05:18 PM   #8
MARKDTN
Re: Tach Filter????
Looks like:
red to coil, there is a tach post on an HEI to put it on
yellow to tach
black to ground
I have always used them (not on a truck though), but I have never seen a 3-wire. The stock ones on later GM cars are just 2 wires.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-05-2015, 06:08 PM   #9
cleszkie
cleszkie's Avatar
Re: Tach Filter????
I ran my repop tach off my HEI for years with no issues. Now I run it off my MSD 6AL ignition with no issues. Never used a filter.
cleszkie is offline   Reply With Quote
