Six Lug Ralley wheels
I have a set of six lug corvette looking ralley wheels, the axle opening is larger than the hub on my 67 c10 rear is it OK to install these and run them?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Six Lug Ralley wheels
Yes,... with the correct "acorn style" lug nuts.
![]() Join Date: Jan 2001
The lug nuts should have a chamfer (bevel) on the end, rather than being flat. The chamfer centers the wheels on the lugs.
You're looking for lug nuts like the ones on the left in the image. |
X2, with above^^^^^ but, it depends on what center cap you use. With OEM Corvette center caps those lug nuts will hit, i had to use standard lug nuts for clearance
#5 | |
X3 I used the OEM style Corvette center caps also. Standard lug nuts were needed for clearance + a set of locking nuts in the shorty style. ![]()
70 GMC Serria Grande Short 70 Chevy C/10 Short LS Powered 72 Jeep J2000 4X4 86 El Camino (22k original miles) |
Good point, got a link?
What I'm asking is, does the wheel opening have to be tight around the hub of the axle or is OK that the lug nuts carry the weight. It's about a 1/4" larger that the stock wheels.
#8 | |
It will be fine.
![]() Join Date: May 2014
The answer is given above. If you're being told to use lug centric lug nuts then the center bore of the wheel isn't centering the wheel. If you were using hub centric lug nuts the opposite would apply.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Thank you all
