Originally Posted by tpankratz
I would like a copy of that water jet file if you still have it. I have a water jet at work and am getting ready to drop a 5.3 in my 79. What trans did you use, and did you have to modify the driveshaft to fit?
Give me your email address and I can send them to you.
I'm using a 4l80e. Mine is 4 wheel drive and I totally redid my transfer case and crossmember for it. With my mounts you could probably bolt the plates up, space the motor and trans so it will bolt up, then weld the mounts up.
