Old 03-07-2015, 11:40 PM   #1
WATSON403
72 gmc rear end swap
I have a 72 gm half ton with an open diff and I'm sick of peg leg burnouts so I want a posi I also have 3.73 gears right now but I want a little more umph I could live with 4.10s but I would rather have something in between anyway Im wondering if you guys know what rear end outta what pickup would be compatible with as little to no fab
WATSON403 is offline   Reply With Quote
Old 03-08-2015, 12:09 AM   #2
k29349
Re: 72 gmc rear end swap
Why not just put a Detroit True-trac diff in your current rear axle?
k29349 is offline   Reply With Quote
Old 03-08-2015, 12:23 AM   #3
WATSON403
I've never messed around with the gears in a diff so doing it myself I just figured it would be easier swapping axles instead of messing with gears and setting backlash
Old 03-08-2015, 12:45 AM   #4
k29349
Ring gear back lash is pretty simple. The pinion depth is where it gets complicated. You would not have to mess with pinion depth. I put a True-trac in my blazer and the back lash stayed the same. It didn't even need adjusted. Watch a few vids on setting backlash and see what you think. I think the True-trac is better than GM factory posi anyway. No clutches to wear out. No need for additives. And probably a stronger unit also.
Old 03-08-2015, 10:39 AM   #5
cla511
cla511's Avatar
I put an Auburn in mine the other day and it rolled right in. Didn't have to change the shims or anything. To me the Auburn is a lot more drivable. A lot less hopping and popping in turns and parking lots. I did keep my old ring gear so that does make it easier.
1972 C10 Cheyenne 402/TH350
1985 GMC 1500 Sierra Classic 350/700R
1986 K20 427/NV4500
1986 K20 Sub 406/TH400
"Life's tough.....It's enough tougher if your stupid." John Wayne
cla511 is offline   Reply With Quote
Old 03-08-2015, 10:45 AM   #6
Mike C
Mike C's Avatar
If you want to find a built rear that meets your criteria it will be (1) expensive if you have to buy it from a builder or (2) a long wait to find exactly what you want used.
The TruTrac is a great choice for a street vehicle as well as the Eaton posi (which is an updated, stronger version of the original posi) or the Yukon DuraGrip which is pretty much a copy of the Eaton.
If you are at all a DIY kind of guy with good mechanical skills you can do a diff swap because you are not messing with the pinion depth.
Get a mag base and dial indicator from Enco. Probably cost $50. Get a deluxe carrier shim kit (interlocking side shims they are MUCH easier to install) and order a posi. I would try someone like Randy's R&P and see if they would install new carrier bearings for you on whatever diff you choose. New ring gear bolts and gasket should be in your cart too.
Measure back lash on ring gear then pull diff apart. Put ring gear on new diff. Put shim packs together duplicating factory setup and reassemble. Measure backlash. Adjust by rearranging shims until it is same as you took it apart.
I could explain in detail, but there are 100's of writeups on the internet about installation that can give you that. Just hit the Google and feel good about ding the job yourself.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-08-2015, 03:57 PM   #7
terry b
terry b's Avatar
I THOUGHT HE SAID HE WANTED TO CHANGE THE GEAR SET? That would be the ring and pinon no?
terry b is offline   Reply With Quote
Old 03-08-2015, 07:00 PM   #8
k29349
Your not going to find a half ton rear end with something between 3.73 and 4.10.
Old 03-08-2015, 08:26 PM   #9
Mike C
Mike C's Avatar
He said he could live with it but didn't specify he had to have it. It's certainly not worth the expense for a 10% increase in gear ratio.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-08-2015, 09:04 PM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Cost will depend greatly on what rear is under the truck...72 GMC's had either Dana 60 or GM 12T...? http://www.ringpinion.com/DiffWizard.aspx
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-09-2015, 12:51 AM   #11
Z10
Z10's Avatar
Try a Richmond Powertrax. I have one in my 69 Camaro and about to put one in my 72 GMC.
Watch the video. Picture is worth a thousand words.
https://www.youtube.com/watch?v=8k-LmnS3ED0
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-09-2015, 01:02 AM   #12
mechanicalman
If it's a half ton, it's probably a 12 bolt. If it's a GMC, it's probably a leaf spring.
Assuming all this is true.....
Any chevy/gmc 1/2 ton pickup with leaf springs where the spring pads measure out the same on the tubes and same width drum to drum, should work as long as it's a five on five, and if the u-joint size turns out to be different adapter u-joints are available.
But as previously stated, I also think a true trac would be the way I would go and keep the 3.73's. Consider that you would NOT have to pull the pinion gear out and could likely use the existing shims on the new posi carrier with new side bearings.
mechanicalman is offline   Reply With Quote
Old 03-09-2015, 09:47 AM   #13
70blackfish
take it to a rearend shop and have them install a posi, you might need a few bearing also like i did. if you have 3.73 don't mess with the ratio. just ad a posi.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
chev, positraction, rear axle
