Old 03-03-2015, 09:51 PM   #1
hdff
hdff's Avatar
Is this going to be a mistake?
I am trying to install a ece super track bar and can not get the old u bolts out. I am working on jack stands so my space is limited. I have sprayed them 4 or 5 times with kloil and pb blaster and have had no luck with a 3# hammer and wedge. Is there any problem that I am not seeing if I take a cut off wheel and cut the U before the bend and take my impact and try to tighten the nut till it gets tight and hopefully turns the remaining straight part of the U. Any war stories about your experiences or opinions are welcome. Thanks
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 03-03-2015, 09:56 PM   #2
kamikazekyle05
kamikazekyle05's Avatar
Re: Is this going to be a mistake?
I just cut mine off and bought new ones
kamikazekyle05 is offline   Reply With Quote
Old 03-03-2015, 11:07 PM   #3
Tree-50
Idk how much space you actually have but I've never found a bolt that could stand up against a breaker bar + jack handle combo for more torque.
Tree-50 is offline   Reply With Quote
Old 03-04-2015, 12:03 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Cut the u-bolts just above the trailing arm. You can then use your impact like you talked about. Should pull it most of the way down.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-07-2015, 08:50 PM   #5
hdff
hdff's Avatar
I won!
"Wanda"
Old 03-07-2015, 09:43 PM   #6
jayoldschool
Moderator
I have yet to meet a bolt that a sawzall or a torch can't defeat.
jayoldschool is offline   Reply With Quote
Old 03-08-2015, 10:37 AM   #7
Rod Run
Rod Run's Avatar
I use heat a lot.
Usually if you get the nut to the point where it's almost ready to start glowing, it will spin right off.
I just had to do it with my adjustable panhard bar last weekend
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
