Old 01-30-2015, 10:21 PM   #901
68 Crew Cab
68 Crew Cab's Avatar
Re: How about some pics of "4x4" Blazers, Jimmy's & Burbs?
68 Crew Cab
Too many trucks...
68 Crew Cab is offline   Reply With Quote
Old 02-01-2015, 12:29 AM   #902
STREET BLAZIN
STREET BLAZIN's Avatar
I drug this 84 home a while back.
The motor is shot and I don't have a clear title for it.
It's in real good shape otherwise so I'm not sure what I'm going to do with it.
STREET BLAZIN is offline   Reply With Quote
Old 02-02-2015, 01:52 AM   #903
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
That is a clean K5 STREET BLAZIN! Good bones to start some kind of project. Title work shouldn’t be too big of an issue to work out. 83’/’84 Chevrolet grills are my favorite of all the squares.
Somehow I missed this thread. Might as well throw the Polar Bear Burb in the mix.
How he looked when I brought her home in Oct 2011
While giving the interior a major cleaning. Factory stick shift truck!
How she looks now
NV4500 swapped in
This is going in to replace the wheezy TBI 350 in a few weeks. Updates will be HERE
DirtyLarry is offline   Reply With Quote
Old 03-03-2015, 09:05 PM   #904
lower50's
lower50's's Avatar
This is my wife's 1987 Jimmy. All original paint top and bottom. No rust anywhere! 35" BFG KM2
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-09-2015, 07:25 PM   #905
BlazerGirl90
BlazerGirl90's Avatar
These were our 4x4 we had a couple of years ago. The lifted one was mine
1970 Camaro
1970 Monte Carlo
1982 Jimmy K5 2WD
1979 Blazer 2wd
1986 Silverado
2012 Silverado
BlazerGirl90 is offline   Reply With Quote
Old 03-09-2015, 08:04 PM   #906
68Timber
I know the pieces fit
68Timber's Avatar
Nice trucks!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-10-2015, 09:15 AM   #907
motornut
78K & 79C Jimmys
motornut's Avatar
Nice seeing others still in Ont.
Salt use has been real bad this year,getting fewer and farther between seeing them
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-10-2015, 09:56 AM   #908
lower50's
lower50's's Avatar
Ya I feel the same way. We bought it in Arizona last April and drove it home. We got it oil sprayed in the fall and kept it washed top and bottom. Just got it oil sprayed again. All looks good. The original paint marker from factory is still on the frame.
1951 MG TD
Old 03-27-2015, 11:37 AM   #909
65Okasai
65Okasai's Avatar
Updated pictures. Added a 14 bolt with 3.73, 6 lugs, and disc. Also put a new engine cover on.
65Okasai is offline   Reply With Quote
Old 03-27-2015, 09:04 PM   #910
CDR
CDR's Avatar
Looks great! Tell us more about that 14 bolt...
CDR is offline   Reply With Quote
Old 03-27-2015, 09:12 PM   #911
65Okasai
65Okasai's Avatar
It's a 14 bolt semi-floater out of a 96 2500. 3.73 w/ gov lock. Slid in new 6 lug axles and converted it to disc. All new bearings, seals, brake lines. Blue torch fabrication diff cover. Had to move some perches around.
Old 03-28-2015, 11:24 AM   #912
CDR
CDR's Avatar
Thanks! It looks really well done. �� I guess there isnt a way to do ff with a six lug axles come to think of it.. I probably will have this swap to look forward to one day, but the ten bolt has served me well so far
Old 03-28-2015, 11:49 AM   #913
65Okasai
65Okasai's Avatar
The 10 bolt that I took out was a peg leg, drums, and 3.08 gears. Figured if I was going to complete a gear and diff swap might as well get a 14 bolt. So I went to a u-pull-it locally and started the process.
Old 03-28-2015, 12:20 PM   #914
CDR
CDR's Avatar
Those drums from the 14 bolt are massive! I'll bet it was handful to move around. The 14 bolt was a sf then?
The swap for the disks..are they gm parts from a nnbs truck?
Old 03-28-2015, 04:14 PM   #915
65Okasai
65Okasai's Avatar
I got the conversion from lugnut4x4.com I believe the calipers are from a mid 80s gm front rotor, not 100% sure on the rotor. The owner is real customer helpful so I'm sure he'd be glad to hook you up. Yeah the 14b is a semi-float and yes the drums weighed a ton.
Old 04-03-2015, 02:18 AM   #916
blazinzuk
blazinzuk's Avatar
Work in progress. 89 6.2 soon to have a turbo 6 lug sf 14 bolt w lock rite and 4.56 gears. Front 10 bolt open 4.56s. 6" lift 37" crappy military tires
Future plans rust free body and full topper conversion
Eric
89 diesel jimmy
86 crew dually
87 truggy Horton
blazinzuk is offline   Reply With Quote
Old 04-13-2015, 12:56 AM   #917
texas4x4hoe
Here's my 85 'Burb. Working on the Cummins/nv4500/np205 swap. Also swapping to the 73-74 front clip.
texas4x4hoe is offline   Reply With Quote
Old 04-20-2015, 03:01 PM   #918
93FatBottom
Here's my hoopty, 79 K5 Blazer, 350/TH350/NP203/10b/12b, all original; A/C and cruise control, manual windows door locks and tail gate. She's a California truck but no smog pump or AIR. Does have a cat converter. She's been non-op'd since 2003. She has what sounds like a lifter knock (smooth constant hollow knock from top rear of engine). Got a full tank for fuel from 2003. Shes dirty rusty and tired. Straight body panels. She's perfect. Total investment, including new Craigslist tires and a new ignition lock cylinder, and a uhaul trailer rental to get her from the previous owners house to mine, under $1,000. She's been parked at my house waiting for my time and dollars. I recently got engaged and switched jobs so after a few weeks of catch up I'll be replacing lifters pushrods and rockers and then the fun begins. Powerplant swap is in the future. Either a 5.3 LS or a 6.2 diesel (to swap to diesel at the DMV, plans for a 4bt swap later down that road, if that is the road I choose.)
93FatBottom is offline   Reply With Quote
Old 05-01-2015, 11:55 PM   #919
'68 Newtricks
'68 Newtricks's Avatar
Local mud hole and Moab last year. Doing Rubicon in 2 weeks But mainly hang around here for my '68 and appreciate the info!!
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 05-04-2015, 06:57 AM   #920
I guess I'll post pictures of my '85 Jimmy with hard top on while it's still mine:
Old 05-19-2015, 06:45 PM   #921
65Okasai
65Okasai's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=670449
Started a build thread, thanks for looking guys!
Jeff
'86 K5 Blazer / Turbo 5.3/80E/NP208C/14BSF
Old 05-28-2015, 02:42 PM   #922
jcramsey
jcramsey's Avatar
Was cruising craigslist early this morning and ran across this 85 Jimmy at a crazy price, listed pretty much in the middle of the night. Went over as fast as I could and now it's mine. Little rust in the drivers rocker and bottom of passenger front fender but very solid otherwise. Gotta fix the transfer case as it sheared off the selector rod flush with the case.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 07-14-2015, 10:30 AM   #923
jcramsey
jcramsey's Avatar
Heres a better pic in my driveway. Transfer case is fixed and she's on the road!
The Egg Hauler
The Government Mule
Old 07-14-2015, 11:47 AM   #924
68Timber
68Timber's Avatar
Sweet!
John
74 Honda Z50 build
Old 07-15-2015, 08:46 AM   #925
jcramsey
jcramsey's Avatar
Thanks Bruiser...and thanks for your help regarding my transfer case issues!
The Egg Hauler
The Government Mule
