Old 03-10-2015, 01:28 PM   #1
berch 69GMC
berch 69GMC's Avatar
loose wire identification
While looking into possible qjet issues due to lack of power, i found this yellow wire dangling behind driver's valve cover. I have the truck about three months and I have thought it lacked power from the start. It has 350 from a 78 camaro, 4 barrel carb, standard intake. Sometimes it stumbles from idle, or cruising at 30mph if I step on it it almost stahls. I have read dozens of scenarios from search, checked for vac leaks to no avail. Hoping this yellow wire is the answer. Thoughts?
berch 69GMC is offline   Reply With Quote
Old 03-10-2015, 01:36 PM   #2
cooperhw
cooperhw's Avatar
Re: loose wire identification
I am going to guess or vote for one of the wires that used to go to the coil that has been replaced by the hei unit.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-10-2015, 02:05 PM   #3
FirstOwner69
FirstOwner69's Avatar
Originally Posted by cooperhw View Post
i am going to guess or vote for one of the wires that used to go to the coil that has been replaced by the hei unit.
x2
FirstOwner69 is offline   Reply With Quote
Old 03-10-2015, 02:07 PM   #4
leddzepp
Moderator
leddzepp's Avatar
X3
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-10-2015, 03:11 PM   #5
67 cst swb
67 cst swb's Avatar
x4
Just check with a test light to be sure its not hot/live.
A stumble usually indicates a momentary rich or lean situation, so I believe your issue is carb related. Assuming of coarse that the weights in the distributor and the vacuum advance are both working properly.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
