Old 03-08-2015, 07:59 PM   #1
rgunlock
rgunlock's Avatar
Positioning Vintage Air system - need help
Hi, I'm hoping that someone who has installed Vintage Air in a 73-87 can help me out. I've already shaved my firewall so have no reference holes to mount the under dash unit. I've got the block-off plate to mark the mounting holes, but I'm not sure where to position the plate in the first place. Does the placement in my picture look right?
If someone has the plate mounted and can post a picture, that would help. I've searched and looked through 12-15 threads but can't find one that shows this block-off plate.
Also, if you've done Vintage Air on a shaved firewall without drilling holes, I'd appreciate a description of how you mounted the under dash unit. I'd prefer that than running the bolts through the firewall.
Thanks in advance for your help
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 03-08-2015, 08:56 PM   #2
J Knight
J Knight's Avatar
Re: Positioning Vintage Air system - need help
Here is a pic of a vintage air plate. I got it from this thread.
http://67-72chevytrucks.com/vboard/s...=433689&page=9
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 03-08-2015, 11:37 PM   #3
xole
xole's Avatar
Here is mine if it helps.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 03-09-2015, 07:42 AM   #4
rgunlock
rgunlock's Avatar
Thanks John and xole! That does help a lot. Looks like mine needs to go down and right so the curved edge lines up with the edge of the hollow space in the firewall. I thought it was odd that the block off plate laid across the edges where the sheet metal overlaps, but it does on yours as well.
Rick
Old 03-09-2015, 08:53 AM   #5
xole
xole's Avatar
The plate is designed for some of the holes to match up with the mounting bracket for the unit under the dash (which also aligns the lines for the refrigerant). Beware...on mine they sent the wrong bracket for the dash unit and I spent a day frustrated at it looking cross eyed trying to get it to line up.
You might want to call them, I would bet they have a generic bracket for a flush mount install.
If I remember correctly there were also some stand off spacers as well.
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
Old 03-09-2015, 10:40 AM   #6
rgunlock
rgunlock's Avatar
I mentioned that my firewall was shaved when I talked to VA while ordering the system. Guy mentioned using the block off plate as a template, but never mentioned any alternatives for mounting brackets.
The instructions make it pretty clear which holes in the block off plate are used for mounting the under-dash unit, so no problem there. Just needed to know where to position the plate so I could mark those holes, although I'm still pondering how to avoid drilling.
Thanks again for the help.
Rick
Old 03-09-2015, 10:06 PM   #7
boatpuller
boatpuller's Avatar
Here'a a pic of mine after I did it. The best one i could find of that plate but you can't see it all.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-10-2015, 02:54 PM   #8
Robert8096
Robert8096's Avatar
Hope this helps.
Before, used the upper right original AC box stud hole to mount the VA inside air box. Had to drill the lower mount hole.
During
Finished
I welded two studs on the VA bracket and then used acorn nuts to secure it to the firewall. Make the holes in the firewall larger than the studs because you have to make sure the inside box sits level for and aft so it will drain correctly.
Under Dash
Robert8096 is offline   Reply With Quote
