03-10-2015, 06:35 PM | #1 |
Little help on CPP Cross member
Ok I need to make some temp. Bushings for my Nascar trailing arms so I can get my leaf spring rearend set up before sending the frame out to powder coat. What I need is the inside measurement on the trailing arm brackets on a CPP Cross member. Mine is on order and not sure when it will get here. Thanks for any help.
03-10-2015, 06:46 PM | #2 |
Quit if it's not FUN!!!
Re: Little help on CPP Cross member
Just call CPP. They should be able to help.
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) |
03-10-2015, 06:50 PM | #3 |
I tried to get them to tell me the U-Bolt center to center on their swap kit and they could only tell me it was for a 3" tube
03-10-2015, 08:57 PM | #4 |
Ttt
03-11-2015, 07:48 AM | #5 |
Ttt
03-11-2015, 07:50 PM | #6 |
Don't know about the CPP crossmember but the stock trailing arm bracket measurement is 2 3/4" inside. The rear u bolts are 4 1/4" center to center.U Bolts are 3/4" as are the traling arm bushing bolts. Hope this helps.
03-12-2015, 07:28 AM | #7 |
Thanks Rudy, That is exactly what I needed. You guys on this forum are awesome !
