Old 03-18-2014, 11:53 AM   #1
First c10
First c10's Avatar
Oil pressure sender with vhx gauges etc
Hello all. I was posting the below from my phone and wasn't realizing it was the lsx classifieds. The question was reading oil pressure from the canbus through DD BIM-01 module not actually able to read it. So the conversation went towards adding the DD sender that came with the gauges. Does anyone have a comment regarding what you did or tried and if it worked or not?
The link to the classified ad.
http://67-72chevytrucks.com/vboard/s...=616431&page=3
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-18-2014, 11:55 AM   #2
First c10
First c10's Avatar
Re: Oil pressure sender with vhx gauges etc
This picture is with the original sender removed.
GO GO!!!
Old 03-18-2014, 08:30 PM   #3
Crash_OK
Crash_OK's Avatar
Mine is setup with the sender separate from the canbus. It works fine that way.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 03-18-2014, 10:22 PM   #4
truckdude239
truckdude239's Avatar
I meAn my stock sensor isnt used you can buy auto meter adapter 2277 m12x1.5 to 1/8
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 03-18-2014, 11:30 PM   #5
kevmac
kevmac's Avatar
Originally Posted by crash_ok View Post
mine is setup with the sender separate from the canbus. It works fine that way.
did you use the unit that came with the vhx gauges? I used it with my 67 camaro but couldnt get the tach to work and wanted to try a combo on the truck
kevmac is offline   Reply With Quote
Old 03-18-2014, 11:33 PM   #6
Crash_OK
Crash_OK's Avatar
Yes.. I used the oil sender and wiring that came with the VHX gauges. All the other functions.. tach, speed, water temp, trans temp, etc are being feed from the CANBUS.
Mark
Crash's 69 4x4 SWB
Old 03-19-2014, 12:52 AM   #7
First c10
First c10's Avatar
DD said they are not able to read oil pressure from canbus so that is why I had to plumb and wire in the DD sender.
GO GO!!!
Old 03-10-2015, 01:00 AM   #8
'68 Newtricks
'68 Newtricks's Avatar
Going to bump this. Hopefully you guys can put a worry of mine to rest.
I went with the DD gauges and interface as well. I also read that it doesn't read oil pressure. So before I installed my '05 5.3, I pulled the stock sender out and replaced it with DD's sending unit.
Maybe I've already answered my own question, lets see.
I'm worried about the computer seeing zero oil pressure and not allowing it to run. Even during start up, there is some oil pressure. Some motors wont allow start up unless 3 psi is witnessed.
Since the DD's OBD2 interface can't see oil pressure, does this mean the computer doesn't either? Will I have an issue leaving my oil pressure sending unit plug disconnected and hanging off the back of the intake, thus not sending that info to the ECM?
Thanks all.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 03-10-2015, 01:18 AM   #9
kevmac
kevmac's Avatar
Thanks all.
I replaced the stock withDD behind the manifold. No issues
Old 03-10-2015, 01:22 AM   #10
First c10
First c10's Avatar
I put a tee in and used the Vhx sender for the gauges and kept the stock LS on for the computer. No problems.
GO GO!!!
Old 03-10-2015, 01:27 AM   #11
dayj1
That won't be a problem at all. The ECM does not use the oil pressure data.
dayj1 is offline   Reply With Quote
Old 03-10-2015, 01:33 AM   #12
First c10
First c10's Avatar
Dayj1
So I didn't have to put the tee? If the ECM doesn't use it then what is it used for? Is it something the BCM read and displayed?
GO GO!!!
Old 03-10-2015, 08:50 AM   #13
H20cooled
My new engine harness does not even have a connection for the oil pressure.
H20cooled is offline   Reply With Quote
Old 03-10-2015, 10:31 AM   #14
ls1nova71
ls1nova71's Avatar
Some of the newer engines use it for DOD/AFM purposes. But GenIIIs do not need the oil sender.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-10-2015, 02:37 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The genIII sender is for an idiot lite only, it doesn't read "how much"....only "if" there is oil.
The ecm does get an input from it, but removing said input does...nothing.
I beleive the genIV's do actually get a value from the sensor, as when you run a scangauge-type device on the GenIV's you can get a PID for oil pressure.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-10-2015, 03:06 PM   #16
'68 Newtricks
Yeah, I think I remember DD saying something about 2008+ Oil pressure working with their interface
'68 C10 SWB
'85 K30 Blazer
Old 03-11-2015, 02:45 PM   #17
solidaxel
solidaxel's Avatar
So can I add the D D sender to the bypass housing next to the oil filter, and leave the stock sender and wiring in place on a 5.3 2003
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-11-2015, 03:23 PM   #18
First c10
First c10's Avatar
I have a genIV and the DD gauges will not work with the computer oil pressure via CANBUS. I had to install the DD sender to get my guages to read oil pressure that is the pictures above,
GO GO!!!
Old 03-12-2015, 09:29 AM   #19
Mayfield
Yes, this is exactly what I did.
Mayfield is offline   Reply With Quote
Old 03-12-2015, 11:58 AM   #20
First c10
First c10's Avatar
I have a factory oil cooler that attaches to the ports above the oil filter. That is why I put the tee at the top of the valley pan.
GO GO!!!
Old 03-12-2015, 03:46 PM   #21
mattcrp1
mattcrp1's Avatar
So just to clarify, my 2002 system 4.8l does not use the oil pressure signal from the sender at all. I could just take it out, tuck the connector back and install a mechanical hard line to my stock '76 gauge?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-12-2015, 10:21 PM   #22
ls1nova71
ls1nova71's Avatar
Yes, that would be correct.
Old 03-13-2015, 12:53 PM   #23
mattcrp1
mattcrp1's Avatar
Thanks guy's. Is the sender a 12mmx1.5 as a previous poster stated?
IG mattcrp1
