-This is my first post-
![]() So, I inherited this truck from my Grandpa, and he bought it from the original owner. It was in Arizona, but me and my Dad drove it out here to Illinois (Crazy trip ![]() What is all of that stuff? Can it be removed? Why is it on there? I prefer the clean look of a chrome valve cover myself Thank you for the help! More pics, below. |
Re: 1983 Chevy I6 Confused.....
If you need more pics, I will post more.
Active Member
![]() Join Date: Mar 2004
my 83 must be same like how painted valve cover.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
Welcome to the board. I believe all that junk is called PAIR - pulse air reaction. It's a sort of passive AIR pump system. All emissions related, of course. These six cylinders were designed long before emissions regs, so all sorts of junk needed to be scabbed on.
Can you take it off? Well, that depends on regulations in your area. Does the engine need all this junk? No. As for the smoke, it's quite possible that oil leaked out from under the valve cover and then rolls down on to the exhaust manifold. These engines tend to leak from both the valve cover and side covers (covering the pushrods).
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
![]() Join Date: Jul 2000
Yep, those two chambers on top of the valve cover are part of the PAIR system. There's a write-up on it and how to ensure it's working in the GM shop manual.
Here's mine. Look quickly, because there's a freshly built 350 in my shop! ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
yes the leak or smoke oil on the exhaust. you cant just yank all that stuff off that varijet has several vacuum lines. I changed carbs and that's not easy. Check local emission laws before remove any thing.
#8 | |
350 most likely keep updated how it goes.
Six's were most common in tan and white trucks. Why? 2 reasons one is price leaders at dealerships. white and tan are neutral easier to sell. Top reason is fleets order their trucks as basic as possible ie. cheap. White and tan were the most common fleet colors. company logos always go with white and most go with tan.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
My truck was originally (and still is) blue, and it was built with a 250. However, I think the six cylinders were more popular in Canada.
