power booster
Hey guys im getting ready to purchase the disc brake conversion kit for my lowered axle from speedway for $250. Im wondering what power booster and master cylinder can I run or am I good with the stock one. 7"-8" single or dual. Etc. Etc. Etc. Thanks for your help guys
Re: power booster
I made my setup (under floor) using a 74 MC and proportioning valve and 8" hot rod booster. On my limited test runs I have found if I hit it hard it locks the tires and will put me thru the windshield. 74 4wd disc/drums for axles and brakes.
Re: power booster
Btt for ya good luck with the brakes
Re: power booster
you don't need a power booster, that's more of a preference
some guys here use the stock mc with front discs though it's a lot safer to use a dual mc easiest one i've seen is a guy here (my crs prevents me from remembering who) cut off the back of the stock mc pulled the guts out of the mc and mounted a new mc behind his old mc then he ran a heim joint from the stock pedal pivot to the new mc, the heim joint ran thru the old mc this maintains the old pedal and pivot i on the other hand took the hard way and made a new bracket and pivot to mount the new mc and booster ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: power booster
what did you end up getting? I ran my dual MC with disc/drum for 15 years without a booster, decided to add one this time.
Re: power booster
I haven't bought one yet. I want to go down to the local auto parts and by a booster and master cylinder. So im trying to find out what year I should tell them. What have you guys gone with. Also proportioning valve
Re: power booster
If you have power steering, I'd go straight to hydro boost and wouldn't think twice about vacuum.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
polishing a turd
Re: power booster
This. Absolutely. Went Hydroboost in my turbo truck and it was night and day over a large vacuum booster
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
Re: power booster
I dont have power steering as of yet. Im still running the dropped axle and dropped springs. But I have a camaro clip frame waiting. Im not familiar with the hydroboost. How does that work
Re: power booster
I'm pretty sure its a corvette set up companies use for the frame mount master cylinder/booster just not sure what year of corvette
Re: power booster
A hydroboost unit uses power steering fluid / pressure to amplify brake pedal effort. Most 3/4 ton and larger trucks use them, most diesels as well. The advantages are higher brake line pressure (better brakes), more consistent and firmer brake pedal feel, and you won't lose efficacy by running a very aggressive (low idle vacuum) camshaft.
If it's going to be a while before you put the camaro clip under the truck and you won't have PS in the mean time, I guess a vacuum booster is your best bet for now. I just recommend HB units every time it comes up because I think the results are that much better.
Re: power booster
Chevy Astro/GMC Safari vans had hydroboost systems too if you want to source the parts from U-Pullit.
Re: power booster
Im sorry this may be a dumb question, but you can only run a hydroboost without power steering?
Re: power booster
Y'know, I don't see why you couldn't.
The only problem I can think of is this: In normal usage, the HB unit gets pressure from the pump. It uses what it needs and sends pressure to the steering box via another high pressure line, as well as a low pressure line back to the PS reservoir. I don't know for sure what happens when you plumb that high pressure outlet to the reservoir. It might be "foaming, puking mess" or it might be "Totally fine". I mean, the Hydroboost unit can't output more fluid than the pump... so... should be fine? Try it and report ![]() EDIT: Here's a guy who did it. I haven't really read the link except to verify that he's done what you are asking. Sounds like he is running an a remote reservoir.
