Re: Help make my mind up: Trans Swap/Rebuild
I'm thinking about going to the t 5 also. If you decide to go that route, here is an article I found online that talks about changing the tail housing to fit better with a bench seat. It also addresses moving the speedo gear.
http://www.autotraderclassics.com/ca...n-193450.xhtml
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
#2 | |
My only comment is that most V8 Camaro World Class T5s have a 0.63 OD which is pretty tall for a truck with 28" or 29" tires and a 3.73 rear diff, unless you have a lot of HP up front. I calculated RPMs using a 0.63 OD gear, 28" tire, 3.73 rear diff and came up with 1833 RPMs at 65 MPH. That's pretty low RPMs. A 29" tire would have 1770 RPMs at 65 MPH. I was worried my 250ci would bog on any sort of incline so I opted for a T5 with a 0.73 OD gear. The 0.73 with a 28" tire gives me 2124 RPMs at 65 MPH and 2051 RPMs with a 29" tire. I was much happier with the slightly higher RPM numbers.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Lugnutz, that makes sense. I will consider that. I have the original 283 that we rebuilt.
My neighbor, literally next door has a t5 from a 92 s10 that I just found out about today. Issue is, pulse speedo. What are my options for getting an electric speedo in my truck? Has anyone used the pulse speedo t5 and also swapped their speedometer?
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 |
#5 | |
It can at some future time be converted to a cable speedo by swapping an S10 tail housing that has a cable speedo connection. To get your speedo working again for pulse (VSS) output units, you can 1. Buy modern gauges 2. Use a GPS instead 3. Cable-X conversion box Some modern gauge sets are very expensive, so watch your budget before you jump in that direction. Nice thing is that you can just use a GPS until you save th money needed to go modern gauges or tail housing swap. A recent thread showing gauges is HERE. Here's a digital gauge I saw last fall at the Charlotte Auto Fair that looks like an original gauge when the power is off.
