Old 03-17-2015, 06:00 PM   #11
trkfrk
trkfrk's Avatar
Re: Ls swap radiator
Originally Posted by fast&low View Post
Yeah I'm just going to give up & move on to the upper hose on the drivers side & just run a 02 Chevy Avalanche upper hose.
Getting ready to pull the trigger on a RnD LS swap radiator with electronic fans.
They can build it the way I want it & for 710.00 shipped to my front door.
I was just looking for a cleaner look but it's just not working out.
Thank you for all your time & I hope you have better luck than I did.
Almost forgot what lower hose are you useing & are you useing a LS truck motor?
Here are the Napa part numbers for my upper and lower hoses. I'm running a Griffen with both inlet/outlet on the passenger side.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
