Closed Thread
Old 03-17-2015, 09:46 PM   #1901
mcgoo26
mcgoo26's Avatar
Re: What did you do to your truck today? Chapter II
Not something done today, but over the weekend. Removed the wheels to have the tires replaced, discovered how bad the front breaks where. After removing the dust caps, found out that a nail is a suitable sub for a cotter pin. Also, no torque on either nut. Hand tight would have been more than what torque was on the nuts. All said and done, both front brakes, calipers, pads, rotors, and bearings changed. Good-to-go!
mcgoo26 is offline
Old 03-17-2015, 09:59 PM   #1902
Possmguts
Possmguts's Avatar
Originally Posted by Gravityamp View Post
Painted now I have to cut and polish .
looks real sharp... did you do the paint?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 03-17-2015, 10:01 PM   #1903
Possmguts
Possmguts's Avatar
Found out I was lied to about how old the build was on my motor so now guess what Im adding to my list...
Old 03-17-2015, 10:56 PM   #1904
85burb
85burb's Avatar
Actually let the wife drive her 67 home from dinner and she broke it. Pulled in to drive way and the driver side rear wheel was smoking. Jacked rear up and tried to turn the wheel. Could not move it. Let truck down and now it won't move at all. Sounds like the wheel cylinder locked up and...... She can't drive the truck ever again
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline
Old 03-17-2015, 11:08 PM   #1905
Chucks72Longbed
Chucks72Longbed's Avatar
McGoo26, hope you didn't torque the wheel bearing nut. It's not suppose to be torqued. Just tight enough to put preload on the bearings. You probably knew this already I am probably reading more into your post than what you wrote.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline
Old 03-17-2015, 11:33 PM   #1906
OregonNed
OregonNed's Avatar
Adjusted the wiper arms to the optimum off position all in the comfort of my trucks new home in the garage
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-18-2015, 06:05 AM   #1907
7tee
7tee's Avatar
Ball joints, front shocks, cleaned and greased front end. Man what a difference in the ride. Now if my new tires would just get here... (this was yesterday)
7tee is offline
Old 03-19-2015, 12:34 PM   #1908
Browns Chop Shop
Browns Chop Shop's Avatar
Dreaming of the day!
Browns Chop Shop is offline
Old 03-19-2015, 02:36 PM   #1909
7tee
7tee's Avatar
New tires, rear brake hose and master cylinder...
7tee is offline
Old 03-19-2015, 02:40 PM   #1910
ole dollor
ole dollor's Avatar
welcome to the forum from a fellow Texan...good luck on your build.
ole dollor is offline
Old 03-19-2015, 03:08 PM   #1911
Browns Chop Shop
Thanks! Its coming along very nice, block and heads are in East Texas getting makeover for .409, Im getting excited.
Old 03-19-2015, 03:09 PM   #1912
mcgoo26
mcgoo26's Avatar
After reading my post again I can see how it may have implied that it needed huge amount of torque. Another part to the task that I didn't mention was before anything was undone, the rotors had about an inch or so, if not more, of play side to side (passenger to driver side) on the hub. As I said, finger tight would have been an improvement. Torqued while spinning the hub to seat or preload everything, backed off then cotter pinned. Thanks for your insight.
mcgoo26 is offline
Old 03-19-2015, 05:19 PM   #1913
BruthaMan
US Army Veteran
BruthaMan's Avatar
I was looking at your truck a few days ago, Ned. It has the most perfect shade of blue I've ever seen on one of these trucks! You wouldn't happen to know the color, by chance?
Welcome from another Texan. Just down the road from you, in San Angelo.
BruthaMan is offline
Old 03-20-2015, 12:44 AM   #1914
meangreen72gmc
Fixed some small dents in my front quarter panels on the 72 k2500 and shot the first coat of primer on them. Small things like that get me excited to see the finished product. Long road of body work ahead before I get to any fun stuff though.
1972 GMC K25 350 sm465
1969 GMC C15 350 th400
2009 Chevy Silverado 1500
meangreen72gmc is offline
Old 03-20-2015, 08:33 AM   #1915
Browns Chop Shop
Welcome from another Texan. Just down the road from you, in San Angelo.[/QUOTE]
Thanks..... I just ordered the painless wiring kit,, puts me one step closer to rolling.
Old 03-21-2015, 12:00 AM   #1916
CST10
CST10's Avatar
Installed a column mounted tach in the ol 68. I like it.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 03-21-2015, 12:02 AM   #1917
74baggedbug
New wheels and tires. 20's 8's&10's
74baggedbug is offline
Old 03-21-2015, 12:14 AM   #1918
mud.man.rj
mud.man.rj's Avatar
What a beauty, my favorite rims too, just icing on the truck cake..
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 03-21-2015, 09:35 AM   #1919
Prematuregrey
Prematuregrey's Avatar
Painless wiring harness and new carpets from LMC.
Before
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline
Old 03-21-2015, 12:40 PM   #1920
hamjet
hamjet's Avatar
Worked more on the 348 the last few days. Still have a lot to do, seems never ending...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 03-21-2015, 02:33 PM   #1921
mud.man.rj
mud.man.rj's Avatar
Never get tired of the w motor, neverending cool.
5.0 4spd std.
7" lift w 35's.
Old 03-21-2015, 02:52 PM   #1922
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by mud.man.rj View Post
never get tired of the w motor, neverending cool.
x2
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-21-2015, 06:16 PM   #1923
berch 69GMC
berch 69GMC's Avatar
Size:  49.4 KBAdded an auxillary input to my otherwise useless radio, thanks to another members instructions. Hardest thing was finding a radio shack still open for business. Installed cig. Lighter assembly. Found a cool jack in the stuff PO included.
berch 69GMC is offline
Old 03-21-2015, 08:28 PM   #1924
Econman
Econman's Avatar
Glad winter is finally over!
Got my engine, converter & trans linked up and bolted into the chassis today. I'll get to crank her soon! Can't wait...
Econman is offline
Old 03-21-2015, 10:50 PM   #1925
Saclandman
Saclandman's Avatar
Spent almost 2 hours trying to get the motor mount bolt to thread. Finally just pulled the mount out, cleared the rubber from the threads, reinstalled the promptly cross threaded one of the bolt into the block. Many profane words were uttered. I was able to replace the rubber fuel lines under the cab and at the fuel pump. Still didn't feel like a very productive 3 hours.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Closed Thread
