Old 02-04-2004, 01:11 AM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
Lightbulb Let's beef up a 250
Guys I want to keep the 250 I6 in my pickup. its a 67 c10 w/ 3 on tree.
I want to get:
> tube headers of good quality (I've seen a few go on eBay).
> 4 bbl Intake and carb. (I've seen a dual carb intake, what cha think?)
> and electric cooling fan and maybe h2o pump.
What do you guys think?
I want to be able to at least compete with a stock V8 but not loose that reputation the 250 has for "going Forever" .
Let's hear it guys. I'm might be rebuilding one of these. I have an extra motor to do this with!!
Thanks, Steven
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 02-04-2004, 01:19 AM   #2
rage'nrat638
rage'nrat638's Avatar
TURBO CHARGE IT......
100 SHOT
rage'nrat638 is offline   Reply With Quote
Old 02-04-2004, 01:31 AM   #3
smitty62
smitty62's Avatar
Want to make a small fortune?? Start with a large fortune and rebuild/modify a Chevy 6
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-04-2004, 01:34 AM   #4
whitesswj
Embrace the Redneck
whitesswj's Avatar
What do you mean? Sorry to be stupid but it's as clear as mudd.
Plus do you have a bigger size of that pic? and where did you find it??
thanks, S
'01 Camaro
Old 02-04-2004, 01:53 AM   #5
oldsub86
Don't waste your money. Either live with the 6 for what it is or pull it and put in an 8. You will never make the 6 equal to the 8 and the parts to improve the 8 are much more plentiful and much cheaper.
I have had a 250, a 292 and a 350.
I like my old 292 well enough but if it has to be rebuilt, it is going to get swapped for a 350 real fast.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 02-04-2004, 01:56 AM   #6
smitty62
smitty62's Avatar
I mean it costs much more to rebuild and/or modify a six than say, a 350. I know, I've been there-done that. Parts are like double or more for a six. Don't take my word for it, check it for yourself.
The picture is from my camera--engine is in my Coupe--love the engine-hate the cost! BTW--all assembly done by yours truly.
Smitty
Old 02-04-2004, 02:00 AM   #7
rn2fine
rn2fine's Avatar
I had a 250 once in a 68 chevelle. A company called "Clifford" out of california (I think) makes a bunch of stuff for the 250. They may still be around. Isky makes a nice cam for the 250 as well. If you change the cam out you will likely need to change valve springs as well. Good luck !!!
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 02-04-2004, 07:44 AM   #8
Cliffords is the main 6 gurus on speed. But like was mentioned, it cost a lot more for the 6 parts than a 350. If your doing it for power, then get a 350. If your doing just to be different, then check out cliffords. Most HIPoi parts are double what you can get for a 350.
Old 02-04-2004, 08:56 AM   #9
Blue Beard
Blue Beard's Avatar
smitty62,
Is that an Offenhauser intake manifold?
Like the picture of the old Chevy, noticed what looks to be a stop light on the building in back of her..........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-04-2004, 10:54 AM   #10
MOTHERTRUCKERS
On my 292 it has a lump port head with 2.05 valves and minor port and polish 700.00, 63 forged steel crank 300.00, H beam rods- forged pistons 800.00, cam lifters screw in studs guide plates springs 350.00, dynamax headers 150.00, ceramic coating 150.00, Offy 4 bbl intake 200.00 match porting 75.00, custom built 735 cfm carb 850.00, ARP studs 120.00, machine work boring decking stress reliving etc 450.00, custom built HEI and wires 200.00, blowing away 5.0 mustangs with an old truck PRICELESS!
For the money a small or big block is way cheaper to build!
If I havent scared you off I have some used Offy 4 bbl manifolds 390 cfm carbs and other 6 cyl parts for sale.
Also 4 bolt main 350 short blocks 010 nickel 75.00 020 nickel 100.00 030 nickel 300.00.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-04-2004, 11:23 AM   #11
dubie
dubie's Avatar
For info and pics on building up inlines go to www.inliners.org
There are some great tips and pics of inlines there. I was going to build up my inline 6 but after weighing the cost and the power I wanted to achieve in the end, I built a 350 for around $2000. I have 2, 250's sitting in my stock right now and I still plan on building up an inline for the next project .
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-04-2004, 11:53 AM   #12
smitty62
smitty62's Avatar
Bluebeard--no, believe it or not, it's an Edelbrock! Found it in so-so condition on Ebay--rebuilt it and I'm delighted ith it. It's heated the same as a stock manifold. Offenhauser has a P-poor system of heating--either with heat tubes or hot water. I love the sound of a six, mine is a bored .060" 235 and has a great split manifold and Smitty's--just like 50 years ago! But the power/cost ratio is way out of line.
BTW--the air cleaners shown are for sale--4 barrels modified to fit the single barrel carbs--$30 shipped. I'm now using 1940 Chevy truck air cleaners with Kohler air filters!
The Red Baron
Smitty
Old 02-04-2004, 05:40 PM   #13
Keep on Trukin
Everything that u are looking for can be found in the JC Whitney
the headers, the 4 bbl intake, and also a holley 530cfm carb to with that 250 inline, i want to do the same to my 250 for my 67 GMC shortie. Check it out.
Keep on trukin!
Keep on Trukin is offline   Reply With Quote
Old 02-04-2004, 05:47 PM   #14
Keep on Trukin
JC Whitney Truck Catalog
Old 02-04-2004, 05:55 PM   #15
bagged91
Out draggin'
bagged91's Avatar
You CAN make a six run.... A freind of my dads is running a 301 Jimmy I-6 in a 57' Chevy 2 dr sedan. The car is all steel and running a 4 speed. He runs the car in the Nostalgia Drags sometimes(he has owned/raced it since the early 60's with this setup). He was an IHRA Natl' Record holder for years with that car running at Englishtown Raceway Park.
I have personally seen that car pull the front wheels 2 feet plus in the air and carry them for the first 40-60 feet. Sounds neat too!!!
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 02-04-2004, 06:57 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
67 CAMARO IN HOT ROD A FEW YEARS BACK WITH A 292 AND A
3 SPD. IT RAN LOW 11'S IN THE QUARTER. NOT TO SHABBY.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-04-2004, 08:27 PM   #17
smitty62
smitty62's Avatar
I for one did NOT say you couldn't make a six run! I said it's too expensive for what you get. Hell, I've been running sixes since 1951--yes, I'm old, but not senile. You put $3000 into a Chevy 235 or a 292 GMC (forget 230's and 250's--poor design--you will find very little in the way of actual speed equipment for them--235 is a much better engine--292 GMC better yet) and you'll have sweet running and sounding engine-a lot of fun.
Put the SAME $3000 into a SBC 350 or 383 and it will run the A$$ off the six! If you want to be stubborn about this, feel free--but do your research.
Smitty
Old 02-04-2004, 09:23 PM   #18
zeeklu
http://www.cliffordperformance.com/
zeeklu is offline   Reply With Quote
Old 02-05-2004, 03:36 AM   #19
Brad
Out of the carpool lane.
Brad's Avatar
I'm confused about your statement. You say the 235/261 is a better design. Why??? Yet you compare the 292 with the 235. The 292 is the same design as the 230/250, it's just got a longer stroke.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-05-2004, 06:50 AM   #20
'68OrangeSunshine
'68OrangeSunshine's Avatar
I ran a 292 on my '68 C/10 stepside [built in '77] to 2002. About 250,000 miles. It was bored .030 over, stock or heavy duty build. I ran a Holley 4 Bbl 390 cfm on an Offy intake, Clifford headers, Mallory coil, stock points ignition. These components would work on a 250 as well.
I'm currently in the process of installing my rebuilt other 292 block. Hopefully when the rainy season is over. Yes it is spendy, but that solid feeling of torque is worth it. V8s just don't last as long. Too many moving parts. I've killed a 327 and a 454 in only the last 10 years. If you factor in the longevity aspect, it evens out.
Old 02-05-2004, 01:31 PM   #21
smitty62
smitty62's Avatar
If you will read my posting I said a "GMC" 292--not a Chevy. Very hard to come by.
Smitty
Old 02-05-2004, 01:46 PM   #22
Keep on Trukin
A start
This is what I am starting out with for my 250 inline.
Old 02-05-2004, 02:11 PM   #23
Keep on Trukin
And this
headers
Old 02-05-2004, 10:02 PM   #24
MOTHERTRUCKERS
I have a good used 4bbl Offy intake for 125.00 and new dynamax headers for 169.00 if interested.
