Closed Thread
Old 03-18-2015, 05:25 AM   #651
Re: What did you do to your truck today part III
Palf70Step is offline
Old 03-18-2015, 03:11 PM   #652
Grizz1963
Grizz1963's Avatar
The towbar has it's second coat of Hammerite.
Today I bought new 8.8 high tensile bolts for all the fittings oft he towbar as well as a pair of even higher spec collared Allen head bolts to make into fixing pins, along with the R-Clips I was given on Monday by the local spares shop.
Measured, then ground flat aspects for the drill to take to, drilled through (sacrificing some bits in the process) and then tidied them up.
This means the towbar is now complete, ready to fit once the truck is ready for reassembly.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 03-18-2015, 03:43 PM   #653
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by jbgroby View Post
Got the front and rear glass installed tonight! Getting a little closer every month
Wow there's a milestone for sure! Been a long time coming, glad to see the progress continues.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 03-18-2015, 10:37 PM   #654
jbgroby
jbgroby's Avatar
I pick up the new battery and grounding cables Friday from Napa as well as the heater core. That is the last of the under hood items left to do. I them put on the steering wheel. Next is the muffler tie in.
jbgroby is offline
Old 03-19-2015, 11:21 AM   #655
Chevy Fleetside
Chevy Fleetside's Avatar
I took a wood shop class at City College and built this box for the back of my truck. It has been sitting in my closet for many years. I know it is more then 7. I have been thinking about breaking it out and maybe using it, either in the back of my truck or in the living room as a coffee table. It is made out of solid white oak and the Chevy Bowtie inlay is African Mahogany. It still needs a finish on it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 03-19-2015, 11:24 AM   #656
Lugnutz65
Lugnutz65's Avatar
From one woodworker to another, very nice. I think you probably got an A in the class. It'd look good anywhere. Good job!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 03-19-2015, 12:50 PM   #657
pimpston65
pimpston65's Avatar
just making sure ALL the 292 bits are here, yes NOS!!! the bottom rad hose is in a box...
pimpston65 is offline
Old 03-19-2015, 12:51 PM   #658
pimpston65
pimpston65's Avatar
found this little gem for $20 and wire wheeled it to like new shine!!!
Old 03-19-2015, 12:54 PM   #659
66Submarine
66Submarine's Avatar
Steel shim head gasket?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 03-19-2015, 01:08 PM   #660
pimpston65
pimpston65's Avatar
head gasket is at the top, steel shim? its a stamped piece. is there a different type? oh the tower clamps are on the way...
Old 03-19-2015, 02:04 PM   #661
66Submarine
Yeah, that's what I thought. All you can buy now (at least afaik) is the thicker composite gaskets.
Old 03-19-2015, 02:39 PM   #662
pimpston65
pimpston65's Avatar
I looked for a month and one day it pop'd up, had to buy 2 seperate items to get the complete set, still missing the water outlet gasket. I just found a guy selling some, but I don't need 14 of them!!!
Old 03-19-2015, 03:13 PM   #663
bhc41051
bhc41051's Avatar
You're using 50 year old gaskets? hmmmm
bhc41051 is offline
Old 03-19-2015, 03:20 PM   #664
pimpston65
pimpston65's Avatar
Yup, if anything goes wrong I will just fix it. Every NOS I have looks great so I trust GM parts lasting 50+ years...
Old 03-19-2015, 07:21 PM   #665
65chevysub
65chevysub's Avatar
Pulled most of my front end off today to drill out 2 broken P/S studs and to replace the water pump. Bolts on core support all came out easy for not being touched for 50 years. I enjoy challenges like this.
65chevysub is offline
Old 03-20-2015, 02:36 AM   #666
Joemomma1
Joemomma1's Avatar
Mounted the passenger side nu crank and door loom. Turns out they're weren't the right spline type but a quick phone call has them on their way. No doubt about it, nu relics is a stand up company.
Joemomma1 is offline
Old 03-22-2015, 02:39 AM   #667
Grizz1963
Grizz1963's Avatar
BIG MAN DAY AT VILLA GRIZZ
CHECK OUT DISASTERBUS' THREAD HERE:
http://67-72chevytrucks.com/vboard/s...d.php?t=648095
Martin took this photo when Kerry was leaving.
Imagine how much fun it was for him to reverse all the way down the drive.
Old 03-22-2015, 10:30 AM   #668
pimpston65
pimpston65's Avatar
got my tower clamps today, missing one dang it!!!
Old 03-22-2015, 10:33 AM   #669
pimpston65
pimpston65's Avatar
got this little guy off my 65p/u since its "correct custom" i thought it wouldnt matter if i put a 15# on it, but since the burban is mostly to all "correct" i will use the 13# one!!!
Old 03-22-2015, 12:02 PM   #670
LDO
LDO's Avatar
Trying to do whatever I can to keep things moving while I wait on weather and $$.
Mocked up the high hump so I can drill some holes.
wife even helped out!
Then I made an adapter for my gas pedal. The high hump came from an earlier year truck with a gas pedal that bolts to the floor and I wanted to use the 66 pedal that snaps on with ball mounts. A little cutting, a little drilling and there ya go. Thanks to member Durg for the idea!
Good enough for now!
My bed full of takeoffs and parts I've painted and prep'd.
My sad front end with my leg sticking thru it...
[/QUOTE]
LDO is offline
Old 03-22-2015, 12:40 PM   #671
Turtleman
Turtleman's Avatar
Your on a Mission LDO....
Looking Good
Semper Fi!
Turtleman is offline
Old 03-22-2015, 12:52 PM   #672
earl84
Time to grow your hair out, Marine!
Your wife will love the truck as much as you do by getting in there and getting her hands dirty. I need a woman like that.
earl84 is offline
Old 03-22-2015, 12:56 PM   #673
LDO
LDO's Avatar
LOL,
actually, I'm teaching MCJROTC so I have to stay within regs!
LDO is offline
Old 03-23-2015, 03:48 PM   #674
Chevy Fleetside
I washed it and then registered for this show. http://dreammachines.miramarevents.com/
Old 03-23-2015, 04:00 PM   #675
JamieGallien
JamieGallien's Avatar
Picked up some new shoes for "Old Blue"...
1965 Chevy C10 SWB Step
(Family Restoration Project)
http://67-72chevytrucks.com/vboard/s....php?p=6043410
1972 Chevy C10 LWB Fleet
(factory auto/l6)
http://67-72chevytrucks.com/vboard/s...d.php?t=580342
JamieGallien is offline
Closed Thread
