Old 03-09-2015, 10:18 AM   #751
jae
Re: Project: Shiro
I'm planning on replacing my LS1 intake (probably the worst stock piece they made) with the tall runner version of that Holley. If you like the look of the stock intake though, FAST makes a really nice piece.
Speaking on looks alone, there's not much that would beat that dual 4-bbl setup, except that ITB/stack setup. Wow.
jae is offline   Reply With Quote
Old 03-09-2015, 10:53 AM   #752
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
I like the Holley setup...
Hart_Rod is offline   Reply With Quote
Old 03-09-2015, 11:23 AM   #753
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Don't lose interest in your project. You will get through the rust repair. It just takes time. I had to put mine on hold for almost a whole year one time. I didn't think I would ever finish it. But now I get to drive anytime I want. Keep your head up.
Please don't put carbs on your motor. Fuel injection is the only way to fly. IMHO
Old 03-18-2015, 11:08 PM   #754
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
Worked on the sheet metal a little tonight...
The corners bunch up when the panels are pressed into shape, these peaks keep the panels from aligning well.
I cut through the raised areas with a cut-off wheel and hammered them flat, I'll weld them up and grind them smooth later.
I cut the rest of the cab corner off and smoothed the edges.
Then I laid the panel in place and marked for the first trim. It will take several trimmings and some grinding to get a tight fit. I am trying to get a tightest seam I can to help reduce the blow through when welding it up.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-18-2015, 11:26 PM   #755
sduckworth13
sduckworth13's Avatar
Re: Project: Shiro
Glad to see you tore into the cab to give it a go. I took a week just mapping my measurements and cutting sheetmetal preparing to weld the panels up. Take your time and measure measure measure. Good luck Buck.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-18-2015, 11:27 PM   #756
C10_ustacould
Re: Project: Shiro
The bottom edge of the cab corner sort of rolled forward which also made the panels not align...
... so I pie cut the the panel to straighten the edge. Will also be welded up and smoothed later.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-18-2015, 11:28 PM   #757
C10_ustacould
Re: Project: Shiro
Thanks bro!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-19-2015, 10:44 AM   #758
knomadd
knomadd's Avatar
Re: Project: Shiro
You're attacking those panels like a pro. I thought you hadn't done this before?? Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-19-2015, 10:49 AM   #759
smbrouss70
smbrouss70's Avatar
Re: Project: Shiro
Those videos must teach you a lot, because it sure looks like you know what you are doing. I might have to get me a set.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-20-2015, 08:23 PM   #760
kitsbeach
kitsbeach's Avatar
Re: Project: Shiro
Man...bodywork...I don't want to know what is under the bondo on mine....
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 03-21-2015, 09:30 PM   #761
C10_ustacould
Re: Project: Shiro
New addition to the Porterbuilt collection I've started.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-21-2015, 10:21 PM   #762
mooseknuckles
mooseknuckles's Avatar
Re: Project: Shiro
Sweet!
mooseknuckles is offline   Reply With Quote
Old 03-31-2015, 07:43 AM   #763
C10_ustacould
Re: Project: Shiro
A little progress,,,
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-31-2015, 10:16 AM   #764
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project: Shiro
Looking Good there Buck!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-31-2015, 10:53 AM   #765
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Killer score on the Porterbuilt gear! Nice work on the cab corner too. Keep up the good work.
Old 03-31-2015, 11:46 AM   #766
kitsbeach
kitsbeach's Avatar
Re: Project: Shiro
That porterbuilt stuff looks a lot more fun than bodywork.!! Pretty sweet looking frame Buck
Kitsbeach (Ken)
Old 03-31-2015, 03:37 PM   #767
jasonhall
jasonhall's Avatar
Re: Project: Shiro
jasonhall is offline   Reply With Quote
Old 03-31-2015, 04:35 PM   #768
C10_ustacould
Re: Project: Shiro
Thanks Mike
I agree, I am not well suited for sheet metal repair!
Originally Posted by jasonhall View Post
I'm not sure what you mean by that.
So... (It's never good when the conversation begins with "So...") So I am thowing in the towel on the rust repair and taking the cab up to DeWayne and his crew at Nsane Hot Rodz. Plans for the moment include blasting and priming the sheet metal, rust repair, as well as powder coat for the frame and suspension parts. I just do not have the talent or the temperment to accomplish the repairs to the level I want them done. I'd like to have a nice straight truck and I think this is the best avenue to reach that goal. While the sheet metal and frame are gone I'll work on the detailing the engine and transmission. Oh, and clean up my garage!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-31-2015, 06:08 PM   #769
slowcpe
slowcpe's Avatar
Re: Project: Shiro
Frame looks good. Looking at that new crossmember makes me want one even more now. Gotta draw the line somewhere.
Understand the body work deal. I'm considering your plan as a backup but going to try and give it a go first.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 03-31-2015, 06:54 PM   #770
GAc10boy
GAc10boy's Avatar
Re: Project: Shiro
Good plan, Buck! Looking forward to seeing their work.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 03-31-2015, 08:04 PM   #771
rydeordie
Re: Project: Shiro
Attachment 1380852
So what is the purpose of this piece? And does it replace anything?
rydeordie is offline   Reply With Quote
Old 03-31-2015, 08:35 PM   #772
C10_ustacould
Re: Project: Shiro
Thanks,and good luck with your bodywork!!
It stiffens the frame and replaces the trailing arm and transmission crossmembers.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-31-2015, 08:38 PM   #773
rydeordie
Re: Project: Shiro
It stiffens the frame and replaces the trailing arm and transmission crossmembers.[/QUOTE]
Ah ok gotcha! thanks!
Old 03-31-2015, 11:22 PM   #774
C10_ustacould
Re: Project: Shiro
Oh... and it's awesome looking!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 04-01-2015, 01:29 AM   #775
swamp rat
swamp rat's Avatar
Re: Project: Shiro
What video's would you be referring?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
