Rear Shock Locations (bagged)
I have searched and searched I have looked at so many different things. I have a huge notch that the po put in and he had these huge horrible brackets above the notch to mount the shocks on. I have cut those out and trying to figure out the best place to mount the new shocks. Can you guys PLEASE share some pics of your rear shock mounts?
Who Me?
Re: Rear Shock Locations (bagged)
Does it look anything like this? This was done to my 65 by a PO. I left it. It worked fine and went along with the rat rod thing. I bagged the front and just used shorter shocks to solve that issue.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Yes it looked alot like that!! I cut it all out because I didn't want it sticking out of the bed! No I am confused on how I'm going to change it.
I cant believe that over 100 people have seen this and only one reply! Thx for the reply!!
![]() Join Date: Aug 2004
The aftermarket shock relocators are usually set up just like the 60-62 trucks, out back and pretty much straight up and down.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
http://talk.classicparts.com/showthread.php?p=88325
http://www.nolimit.net/tech-center/6...on-kit-1963-72
#7 | |
![]() Join Date: May 2007
I kept roughly the same shock angle.
![]() you need long travel gas charged shocks for bagged trucks, or the bags will overwork them. with a stock bed floor that usually means relocated upper mounts. Quote:
You are totally right Joe I guess I am a lil impatient! lol I was contemplating something similar to yours would you by chance have a pic of the lower mount?
its an s10 air ride technologies air bar with that piece you see in the first picture added. thats about it!
here is the air bar, we did not use the locations for the shocks shown ![]()
