Old 03-12-2015, 07:21 PM   #1
James Pierce
Brake Booster Rebuild or Exchange?
Which is best way to go? Have a 69 Delco M drum unit to replace standard
brake master cyl. If I go with rebuild kit then how hard is it to get disassembled? And who has parts? If I exchange then where is best place to purchase. Already have new Delco master cyl. Also made new lines for same.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4WD 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
71 GMC Supr 350 Auto
70 C10 350 Auto
67 CST 327 Auto
James Pierce is offline   Reply With Quote
Old 03-12-2015, 07:45 PM   #2
John H.
John H.'s Avatar
Re: Brake Booster Rebuild or Exchange?
Send it out to booster Dewey at power brake exchange in Portland, Or.
http://boosterdeweyexchange.com
John H. is offline   Reply With Quote
Old 03-12-2015, 07:51 PM   #3
davepl
davepl's Avatar
I had an original done at BrakeBoosters.com after the reproduction/replacement unit was unusable. In this case he even supplied the core because I didn't have a good one.
He took care of getting the case polished (lots of work, don't plate without doing it, no point) and replating and rebuilding and what you see here is what came out of the box.
Ignore the MC lid, that's my horrible fake plating job, not related to them.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-12-2015, 10:24 PM   #4
oldertruckfan
Is the truck a daily driver or a show truck? for a daily driver I'd go to Auto Zone or Advance. they're in stock to fit the 72.
oldertruckfan is offline   Reply With Quote
Old 03-13-2015, 06:07 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Brake Booster Rebuild or Exchange?
What he said.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-13-2015, 08:08 AM   #6
snipescastle2
snipescastle2's Avatar
better to leave the rebuilding of the boosters to people that do them, these are under spring pressure, and if you don't have the correct tooling to hold/capture these, the parts will be launching at you at a pretty good velocity, I wouldn't want one coming apart at me, be safe, don't try it at home.
Have a good one!
Ben
snipescastle2 is offline   Reply With Quote
Old 03-21-2015, 03:14 PM   #7
davepl
davepl's Avatar
Years ago I opened one up to see what's inside. Luckily the half that wasn't in the vice flew across the shop and three stalls over put a pretty wicked dent in the side of my 1969 RS/SS 396 Camaro, I think about a thousand dollars damage.
Why do I say luckily? Because if that think would have hit me in the chest, I think it would have killed me.
Do not play with them.
Old 03-21-2015, 03:16 PM   #8
davepl
davepl's Avatar
That was what I did the first time and it failed. The booster might be fine, but the studs were too short to mount the master cylinder and the combination valve bracket. This might be a 3/4 ton thing only.
If it interchanges and fits, I don't see a reason not to go parts-store. But when I did it didn't fit.
Old 03-21-2015, 03:31 PM   #9
7tee
7tee's Avatar
I used Dewey on my Corvette restoration, great job...
7tee is offline   Reply With Quote
